window trouble
Old 05-31-2010 | 05:32 PM
sethery's Avatar
Default window trouble
I believe my driver side window switch in my 02ss is gone out, dealership wants to charge $75 just to look at it. Took all the visisble screws out and still can't get door panel off. Don't know much at all bout this stuff please help!
Old 05-31-2010 | 08:08 PM
lucian*91's Avatar
th panel has clips on it too holding the door panel on and has to be pry'd off startiing on one side and working your way to the other side
Old 06-01-2010 | 01:37 AM
Sliver's Avatar
Check out the 'How to' section on this forum, there should be a write up in there.
Old 06-01-2010 | 01:47 AM
albert1's Avatar
it's pretty easy to take off. there is one screw on the door handle, two on the handle where you pull to close the door, and one on the small quarter panel next to the side mirror. and the rest is pull out throughout the lower panel and after you get them all off, pull he whole thing uprightward to unmount it. the switch cost me about 50 dollars at checkers... it's probably a 1 hour job. good luck.
jeffsmonte
11-21-2022 08:34 AM
Jester_20
08-24-2014 03:29 PM
02 Earnhardt Monte Carlo SS
11-10-2011 11:13 AM
TrapShooter8
06-03-2007 09:31 PM
bumpin_monte01
07-08-2005 09:32 PM
