window trouble
Old May 31, 2010 | 04:32 PM
sethery's Avatar
Default window trouble
I believe my driver side window switch in my 02ss is gone out, dealership wants to charge $75 just to look at it. Took all the visisble screws out and still can't get door panel off. Don't know much at all bout this stuff please help!
Old May 31, 2010 | 07:08 PM
lucian*91's Avatar
th panel has clips on it too holding the door panel on and has to be pry'd off startiing on one side and working your way to the other side
Old Jun 1, 2010 | 12:37 AM
Sliver's Avatar
Check out the 'How to' section on this forum, there should be a write up in there.
Old Jun 1, 2010 | 12:47 AM
albert1's Avatar
it's pretty easy to take off. there is one screw on the door handle, two on the handle where you pull to close the door, and one on the small quarter panel next to the side mirror. and the rest is pull out throughout the lower panel and after you get them all off, pull he whole thing uprightward to unmount it. the switch cost me about 50 dollars at checkers... it's probably a 1 hour job. good luck.
jeffsmonte
Nov 21, 2022 07:34 AM
Jester_20
Aug 24, 2014 02:29 PM
02 Earnhardt Monte Carlo SS
Nov 10, 2011 10:13 AM
TrapShooter8
Jun 3, 2007 08:31 PM
bumpin_monte01
Jul 8, 2005 08:32 PM
