Car powers down under acceleration
Old Jun 26, 2013 | 08:24 AM
garhar's Avatar
Default Car powers down under acceleration
This is a problem that is getting worse to the point of being dangerous. When I accelerate - with or without the Traction Control system on - the engine cuts out all power down to an idle, the check engine light comes on and immediately goes off and the Service Traction Control System displays on the dash. I have to completely remove my foot from the gas pedal and get right back into it to go. After this happens the Cruise is disabled and I have to shut the car off and back on to reset this whole system. It seems to be worse on hard acceleration and wet pavement and has even happened when I hit a bump. I have replaced both front Wheel Bearing Hub Assembly's, rotors and pads and replaced the Vehicle Speed Sensor (VSS) Cleaned the ABS connectors and nothing has helped. Has anybody heard of this.
Old Jun 26, 2013 | 10:43 AM
That sounds pretty friggn weird for sure....
But im sure someone will chime in and help you out with it! Maybe...
Its something as the TPS? (throttle position sensor) Try removeing it...Give it a through cleaning and replace it and see if that doesn't help.
Old Jun 29, 2013 | 09:40 AM
garhar's Avatar
I installed new TPS, Spark Plugs, Wires, Cleaned Throttle Body........... No Change. I thru in the towel and took it to the dealer. He said codes point to lack of communication between the 3 computers ( Electronic Control Module, Transmission Control Module and Anti Lock / Traction Control Module ) He said they unplugged all connections, cleaned them and plugged them all back in and its working fine now. They said they could not see anything obvious and said it must have been a corroded connection somewhere.
Old Jun 29, 2013 | 10:21 AM
Hi Garhar & Welcome to the MCF
I'm not a tech or a expert on your problem, but to me it sounds like you have a bad connection (short) 'if it's happening when you hit a bump in the road.
I suggest cleaning all your connections. How many miles on your S.S.
Please check back on your problems to see what our expert tech MCF suggest > Good Luck
Old Jun 29, 2013 | 12:05 PM
03SSLE's Avatar
The 'has even happened when I hit a bump' is what has me wondering. Did you happen to be accelerating when you hit that bump? All the other symptoms you mention makes me think there might be an obstruction in the exhaust system. Is your idle erratic? Hesitate/Surge under light throttle? Have your cat converter checked.
Old Jul 2, 2013 | 08:16 AM
garhar's Avatar
I have no problems since the dealer cleaned all the connections and plugged everything back in. Unfortunately the dealer could not tell me exactly where the problem was. Miles on the car are 75000
Old Aug 5, 2013 | 09:03 PM
Duderino's Avatar
i had the same problem,,it ended up being the Throttle Body being caked in carbon,,took a whole can of intake cleaner,,now its somewhat normal,,but my symptoms was i pressed the gas and after 2000rpm it was like total shut off from the engine and id cost till it came on again,,,
Duderino
jcquick
Oct 25, 2012 09:20 AM
xman23
Sep 4, 2009 05:23 PM
MARK4648
Jul 4, 2009 06:35 PM
The Popcorn King
FWD Tech Guides '95-'07
May 26, 2008 06:31 PM
White05LT
Aug 26, 2006 09:13 AM
