Loud sqeauling sound
Old Aug 5, 2013 | 10:31 AM
John Cn'tgetRite Veal's Avatar
Default Loud sqeauling sound
I changed my front brakes about a month and and left the rotors on, no problem.
So yesterday I changed my hub bearings which were bad, but my rotors were stuck to them so I replaced the rotors as well. Got everything off put everything new back on, and started driving and my front end has this constant squeaking noise, like metal constantly rubbing, Hit the brakes it stills sqeaks until everything stops. The moment I get back to moving it starts back up again. Problem never existed until I changed out everything, pulled over after running it to work this morning and not much but you can see a little smoke coming from my wheels. did I do something wrong when I put them back on or is it major.
Old Aug 5, 2013 | 11:35 AM
Based on the smoke, something is not right. You could have a caliper not fully retracting the piston and now that you have full material on pads and rotors, it's dragging.
You could have something not assembled right or loose.
Best thing to do, get the front end in the air, back wheels secured, car in neutral and spin the wheels, listen and look for issues. Take the wheel off and again, inspect for issues. Re-check the bolts. Have someone press the brake and watch the pad, see if it's moving like it should.
Old Aug 5, 2013 | 02:47 PM
Question
Quite possibly..
You "overtightened" the wheel bearing also
Old Aug 6, 2013 | 08:33 AM
Thanks guys, it was the metal disc held on by the hub that was pressed up against the rotor.
iMuf
Jan 15, 2014 09:07 PM
Joe Bloggs
Sep 10, 2011 12:07 PM
DJTJ
Jun 14, 2011 08:40 AM
rgant_19
Jul 20, 2009 02:19 AM
