No acceleration under hard throttle
Old Oct 24, 2012 | 11:13 PM
jcquick's Avatar
Default No acceleration under hard throttle
I have a 2003 Chevy Monte Carlo SS, 3.8L V6. I recently changed the throttle position sensor on the car because of a code I was receiving (I don't remember the code). I'm now receiving another code. It's P0122, my scanner said it was the "Throttle Panel Position Sensor". But under the list of codes, that reads: DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage.
The car drives fine under regular driving, cruising and normal acceleration. But under hard acceleration the engine bogs down and I get nothing. No revs, no acceleration. I also noticed if I throw the trans into neutral, I can rev hard without any issues.
Please let me know if you guys can help. Thank you.
Old Oct 24, 2012 | 11:50 PM
MonteSSS's Avatar
fuel pump?
Old Oct 25, 2012 | 12:06 AM
nitehawkjcb's Avatar
Clean the MAF, but if you cleared codes and that one came up, you may have gotten a bad TPS. Check all the wires going to the TPS.
Old Oct 25, 2012 | 09:12 AM
jcquick's Avatar
I'll clean the MAF sensor but that really should bog down the car. I guess there is the possibility I have a faulty TPS. If there are any other ideas, please let me know.
Old Oct 25, 2012 | 09:20 AM
Fuel Filter, Catalytic Converter come to mind
Check the IAC also...
blades3001
May 16, 2020 12:32 PM
Ardell
Feb 20, 2014 05:49 PM
MARK4648
Jul 4, 2009 06:35 PM
The Popcorn King
FWD Tech Guides '95-'07
May 26, 2008 06:31 PM
White05LT
Aug 26, 2006 09:13 AM
