trans swap
Old Feb 7, 2014 | 06:37 PM
wertio12's Avatar
Default trans swap
will a 03 buick lesabre transmission fit a 03 montecarlo ss both have 3800 engines
Old Feb 7, 2014 | 07:55 PM
soaxin's Avatar
Yes it should. Did a little research. It should have the 4th which is the same as ours.
Old Feb 7, 2014 | 08:00 PM
wertio12's Avatar
thanks someone said it would work long as it from the same year just wanted to be sure
Old Feb 7, 2014 | 10:37 PM
l67ss's Avatar
Make sure to check the gear ratios.
Old Feb 8, 2014 | 07:12 AM
wertio12's Avatar
what if the gear ratio is different i cant use it
Old Feb 8, 2014 | 12:57 PM
l67ss's Avatar
You'll wish you didn't use it if it has the wrong gears
Old Feb 8, 2014 | 06:12 PM
wertio12's Avatar
what it wont shift right
Old Feb 9, 2014 | 12:56 AM
l67ss's Avatar
With the check engine light off it'll do all sorts of things. Skip gears, cutout Tom's skyrocket, delayed engagement among others. With cell on it'll drive somewhat ok butll have issues. Also make sure it has an internal park/neutral switch, otherwise it wont start. I'm speaking from experience as I'm running a 3.29 geared 4t65 with a pcm programmed for 2.93s.
Old Feb 9, 2014 | 05:16 AM
wertio12's Avatar
ok thanks
monoxide85SS
Nov 25, 2010 12:08 PM
86monteguy
Oct 24, 2009 11:13 PM
loudNproudSS
Nov 18, 2008 06:57 PM
montes my python
Sep 14, 2008 07:51 PM
Tiderfish
Jan 24, 2007 01:50 PM
