My monte is dead :(
Old Jul 28, 2012 | 10:26 AM
  #151
Ricks 2006 SS's Avatar
Frank after reading all this. And it's only 1/2 way thru it. I'm waiting for the Movie version to come out. No seriously your doing GREAT and you have a good friend in Maniac helping you out. . Who's going to play you in the movie ? and who's going to play Maniac ? Keep up the blog on this. Its a great read My fingers are crossed for you both!
Old Jul 28, 2012 | 10:49 AM
  #152
Franks 03SS's Avatar
2011 Monte Of The Year
Ok so I found some Small hooks and I was able to use the new chain the hoist came with lol
Looks like I'm going to have to remove that piece with the Brake lines connected on it, what's that part called? Lol
And even still it's going to be a tight fit
Old Jul 28, 2012 | 10:57 AM
  #153
thanks Rick
I get all the help from here and Im trying to get my monte running as soon as I can lol this will be one long movie cus idk when I'll finish haha
Old Jul 28, 2012 | 11:59 AM
  #154
WOOHOO!!!
i only had to remove the oil filter and move the fuse box to the side haha
and there seems to be a bolt missing where the trans bolts to the motor? lol
now to get the trans off, i have to remove the starter... unbolt the flywheel from the TC and then remove the bolts on the trans case to the motor correct?
Old Jul 28, 2012 | 12:14 PM
  #155
Budsjlm's Avatar
Don't be afraid to drop the subframe some that will help to give you that little but more clearence, also tipping it will probably help you pull it, so your pulling up the belt side of the engine out higher than the trans side, that way when you get it to clear the fender you can swing the engine toward the pass fender and should clear the brake master cylinder and whatnot, this is decried mostly easier with two people
Old Jul 28, 2012 | 12:18 PM
  #156
Budsjlm's Avatar
Ha disregard my last comment lol, yes unbolt the starter, and Tc from the flywheel, the the trans from motor, on my sisters truck I left the Tc bolted to the motor and just unbolted the trans but you run the risk of messing up the splines on the input shaft doing it that way
Old Jul 28, 2012 | 12:23 PM
  #157
Your getting there Frank
Old Jul 28, 2012 | 12:24 PM
  #158
lol its ok man
well im just to transfer the trans over to the next motor so the TC is staying with the trans
going to pressure wash all the gunk from engine probably tomorrow morning, its a complete mess lol
Old Jul 28, 2012 | 12:25 PM
  #159
I know, probably the hardest part will be getting the motor in without breaking something and the polishing will probably take the longest of all :p
Old Jul 28, 2012 | 11:45 PM
  #160
Probably going to get a full length seatbelt and loop it twice when I put the L26 in I don't wanna scratch up my UIM with that rusty chain lol
Could leave the UIM off when you drop the new engine in.... It's no big deal to put it on after the fact
Also, congrats on finishing the "extraction" of the old motor!! THat is a feeling of VICTORY!! And once the new motor is in and "purrin'", then you can truly celebrate
