My monte is dead :(
Old Aug 5, 2012 | 10:17 AM
  #251
OK, I did some re-researching on the Bonnie forum (been a while since I had to pull this info on the water pump). Keep this in mind for future reference (as if the pump is not bad, I would not worry about it, but if/when it fails, UPGRADE). Also, I wonder if the original owner of your S3 had a pump fail and get a S2 style replacement (since they are interchangeable, that's easy to see happening).
To get the cat impeller your options are:
1. - Buy a S1 pump from the parts store. Your S2 pulley will not fit, as the hub is different. Solution, either buy a new pulley or hit up a salvage yard and get one from a S1 car.
Originally Posted by Wilwren (Bonnie Forum)
You MIGHT have to go to a wrecker for the pulley. Any GM FWD 3800 from 1987 to 1994/5 (Series 1) will be correct, NOT 1995 L36 cars though.
2. - Buy a S3 AC Delco water pump (uses the same pulley as the S2). AC Delco Part Number 252693.
Here's a good link on the subject:
View topic - What looks to be a coolant leak...'00 SSEi : PontiacBonnevilleClub.com
The Series 1 AC Delco water pump impellers are a far more efficient design (cast, curved blades) than the Series 2 stamped impeller, and is less prone to cavitation. It will move more water smoothly at higher rpm's than the S2. This is especially important on cars with raised shift points, although the few seconds of cavitation may not have much of an effect. Even the curved profile of the casting helps with flow. It's a gradual lift towards the shaft when compared to the S2 pump.
Again, food for thought. Given anymore thought to what to do about the PCV vac issue??
Old Aug 5, 2012 | 10:37 AM
  #252
Franks 03SS's Avatar
2011 Monte Of The Year
hmmm getting that WP is tempting lol
and nope havent thought of anything else with the pcv issue
Old Aug 5, 2012 | 10:48 AM
  #253
That WP is $21 new, definitely want it now going to check the Junk yard for the pulley first though hopefully tomorrow, dont like this forecast at all
Old Aug 5, 2012 | 12:05 PM
  #254
brendan127's Avatar
i know this sucks
it has 171k i believe lol
i'll keep yall updated when i get the car home and inspect it a little more
:O My motor has 175k, hope mine won't be going anytime soon. I see in your sig it's an L26.. I thought you said it was an Impala motor, the Impala had a L36 just like our cars.. you know with the L26 you'll be dropping about 30hp right?
Old Aug 5, 2012 | 01:53 PM
  #255
Yea it's a series 3 from an 05 GP how will I lose 30hp?
Are you saying that i'll have less HP than a 3.4 monte?
Old Aug 5, 2012 | 03:04 PM
  #256
You aren't dropping an HP don't worry there lol
Everything is looking great! I can't wait for you to drop it in either
Old Aug 5, 2012 | 03:05 PM
  #257
He'll be keeping the same amount of horsepower with less potential issues.
easy..... lol
Old Aug 5, 2012 | 04:08 PM
  #258
So I got to clean up the heads some (forgot to get pics haha), also have a question about the gaskets, I set them on the motor and noticed that the there's tiny holes where the top coolant ports are on the block. The original GM gaskets were the same way, aren't they supposed to be fully open? Wonder why they're like that lol
Old Aug 5, 2012 | 04:12 PM
  #259
I wasn't worried haha
Thanks mike
easy..... lol
Lol precisely
Old Aug 5, 2012 | 09:24 PM
  #260
brendan127's Avatar
I'm pretty sure the L26 has less horsepower, like 170 or 174.. then again I wasn't looking at one from an 05 GP.. cause I thought the motor came from an Impala which wouldn't have been possible since it was an L26 anyways, lol.
