3rd Gear
sounds like converter lockup your feeling which is normal to an extent. it shouldnt be horrible but when cruising it should lockup (rpm's lower) to keep ease on the trans, better gas milage, and keep the trans cool and then as soon as you let off the gas or lay into the throttle it should unlock (rpm's raise)
Okay, that's exactly what it does. When I give it a good amount of love or let off the gas the rpms raise. I just thought it was weird that it'd go down to around 1200 rpms in 4th at around 45 mph. But I figured it was just me being paranoid because I've had it for only five days, and I haven't owned an automatic in years and even that was a 19 year old tranny. Thanks for putting my mind to ease!
Lower mounts could be starting to go.
6th Gen ('00-'05): launching automatic 4 speed in 3rd gear on monte
brandar
04-05-2014 01:01 PM
6th Gen ('00-'05): gear set, 4th gear hub, channel plate gouged! help!
turbo monte
04-04-2013 10:01 AM
