6th Gen ('00-'05): '01 3.4 Fan removal
Old Aug 16, 2012 | 02:31 PM
New2MonteNY's Avatar
Default '01 3.4 Fan removal
What's involved in taking out the fans in an '01 3.4 Monte? Thanks.
Old Aug 16, 2012 | 03:43 PM
Budsjlm's Avatar
shouldn't be any different that a SS
pull upper motor mounts, top rad hose, two top mounts for radiator,2 10 mm bolts on the engine side of the rad(about in the middle fron top to botm,one on each side left and right), metal clip on top of radiator and mine had a plasic push tab at the botom, unplug fans and undo the holders
i pulled the airbox out for easier access to the bolt on the drive side
Old Aug 17, 2012 | 06:18 AM
OK Thanks...I saw the 2 10mm bolts...I'll give it a whirl 2day.. Thanks again.
gmartinez93
May 11, 2015 10:45 PM
NYGiantsfan
Aug 15, 2013 07:43 PM
jhbasse
Jan 15, 2013 06:39 PM
seth_06
Dec 2, 2006 05:42 PM
ginasmontecarlo
Jan 27, 2006 03:40 PM
