My monte is dead :(
Old Jul 24, 2012 | 12:15 PM
  #61
Pretty sure our cars take 1.5 pounds? They definitely take more than usual.
I just redid mine & it only took .9 somthin
Old Jul 24, 2012 | 03:11 PM
  #62
Franks 03SS's Avatar
2011 Monte Of The Year
You can use them, but if the car isn't running right, that would definitely be the first thing to check as opposed to thinking you did something on the swap wrong
I'm not sure on the transmission, try emailing TEP, ask him for any recommendations on a rebuild. I'm sure he would be willing to share some knowledge.
I think you might have to recharge. The whole system is closed, I don't think you can remove a compressor without losing the freon.
yea i guess i could try those wires and see how it runs
as for the trans i'll send them an email later tonight
and yea i guess i will just get a recharge, the most important thing is to get it running first lol
Yeah recharge ac system is easy freon is like $24 a lb up here & cars take less than that
i really dont know crap about the ac system lol
Oh man, this sucks Frank !!! I had to do my motor last year but I am glad i did I Love this car !! They had a pump and the shop I was at and just held it until the swap was done then we recharged my system with the old stuff.I got a new Motor form LkQ with a 3 year warranty /100,000 mi for mine but I plan on having mine for a long time. And I had a Shop put it in .We redid the tranny at the same time so it was all new . Best of luck man !!!
yea i remember you getting a new motor man
i hope mine lasts me a while, i need to do everything right while the motor is going to be out the car
man Franks that sucks.... Sorry dude.
Its cool tad
I've never done valve seals, but watched a couple of youtube videos. If you do them with the heads ON the car, you need remove the plug of the cylinder you are working on, use some attachments on a compressor to force compression in the cylinder and prevent the valve from dropping in while doing the job (hence why if you pop the heads off, that would be the EASIEST time to swap the seals).
And from what I understand, the rockers and springs need to be removed. In general, the task looks super easy, but if you're going to consider it, just punch it up on YouTube, you'll find a couple great how to's.
I'm just throwing it out there. Granted, I did head gaskets on my '94 Grand Am at 180K, it now has almost 220K and I have not seen any adverse effects of not changing those seals (but I still wish I did since it would have been REAL easy). But I did de-gunk/grease/clean the crap other those heads, rockers and pushrods (looked almost like new, so clean you could eat off them).
There is a lot to consider when the engine is sitting out in the open that is now EASY to do.
Another thing to do, replace the exhaust bolts (even if they don't snap). They are old and brittle. Again, future preventative maintenance.
man i have some work to do then lol
lets just hope everything goes well as ive never done this before lol
Old Jul 24, 2012 | 03:23 PM
  #63
so i got a motor today, L26 from an 05 GP for $400 unknown mileage lol hopefully its a good running motor. it did come with 101 day warranty so thats a good thing i guess. i personally saw the the car in the yard and it was in great shape. was wrecked on the side, driver door. leather in it was in great shape too so it looked like it was taken care of
i started working on mine and got most of the harness wiring out the way, also alternator and other accessories. i have to drain the fluids now and get the suspension out of the way to get the axels out
thats probably going to be tomorrow though. what sucks is that i work wednesday-sunday from 3pm to 11:30pm or sometimes later so im not going to have much time to work on it during the day
anyway i have some questions. on the L26 i noticed that on the UIM it has the EVAP/vacuum lines that L36's have on the TB. will i just have to block that off if i decide to use my TB with the L26 UIM? and will i be able to run those L26 coils or should i just use my L36 ones?
Old Jul 24, 2012 | 03:27 PM
  #64
I also have a question & dont feel like making a thread whats the main differences between a L36 & L26?
Old Jul 24, 2012 | 03:28 PM
  #65
Pics of course
L26
Old motor
there was coolant all on my TB when i removed it and you can see how bad my UIM was leaking lol
some progress lol
Old Jul 24, 2012 | 03:31 PM
  #66
turbo monte's Avatar
FYI - I just sent Frank a PM (so Frank if you are interested, just PM me, we'll work out the rest). I'm also willing to seperate the trans.
A big draw for S3 is that the parts are forged not cast (from what I hear). So tougher inards.
As for the S3, if what I read from the Bonnie folks, the '04 S2 is really a S3 with a S2 UIM. To put this S3 into you Monte, you have two main options:
- Get an adaptor plate and a L67 t-body
- Take off the aluminum UIM and put the S2 plastic UIM and t-body on
(as Chibi said, i believe you also have to bring your fuel rail and injectors)
As for the rest, swap sensors and wiring harness over, drop it in. Done. This is based on some light research I've done in the past.
As for the trans, because the donor car of my drivetrain is an '04, I believe it has the same trans, but I don't know gearing or any other details.
Any engine you get, that you have NOT heard running, I would advise doing some tear down and inspection. Pull the oil pan, pull the heads (it's a little in new gaskets, but do some basic checks OR completely re-build).
ive never heard of the series 3 N/A engine (L26) having forged internals but i could be wrong. i know the series 3 SC engine (L32) has forged internals
to do this swap you will need the adapter plate from zzp. your fuel rails and injectors will work. there is some other things you would have to do to swap the plastic plenum on, you just cant pop it on and go. there is a emissions port on the series 3 that is not on the series 2 so it would need plugged by just swapping upper plenums. i highly recommend getting the adapter plate the aluminum plenum is better anyway and you can make them shiny
the harness will swap right over and trans will bolt right up.
actually the series 3 rails wont even work because they are a returnless system and your car is setup to return unused fuel so you have to use your rails. they fit trust me i have the L36 rails and injectors, L26 plenum on my car with a L36 lower intake, L26 heads, L67 bottom end.
Im considering getting that motor out of Jasons garage
so basically an L26 will work with my trans? im just going to change out the solenoids on my trans and it'll be good to go. i would love to keep that L26 alum UIM. wont i just need that adapter from zzp? or do i have to modify other stuff? even if i didnt use the l26 UIM i could just use my l36 UIM and it'll bolt right up to the L26 LIM?
i did some searching around and found some info on a 99 Bonnie L36 to L26 swap. would all that info apply to me and my monte?.... e.g. is the oil filter adapter on L26's the same as ours? what about that rear manifold?
here's the link to that swap >> View topic - L36 replacement or swap to L26 : PontiacBonnevilleClub.com <<
it will work with the trans no issues. all you need is the adapter plate from zzp to use the l26 plenum, its easier to do this than putting the l36 plastic plenum on do to having to plug emissions ports or you will have vacuum leaks.
the swap would apply to you but your going the opposite way so not exactly. i think the oil adapter is the same. the rear manifold may be different material but made to fit the same way.
ok thanks mike
looks like my monte will be having an L26 transplant soon then
cant wait to polish up that UIM
Stuff i have to do/replace:
Trans solenoids, new filter and fluid
new plugs and ZZP wires
oil change and filter
coolant elbows
new fluids (coolant, power steering any others?)
gaskets maybe? i read these motors have upgraded gaskets or something like that?
Transfer needed accessories/parts
TB adapter
anything else?
DONT USE ZZP WIRES! there junk and will cause nothing but issues down the road its almost guaranteed. either use ac delco wires which are factory replacement or if you want aftermarket wires but PRJ wires. PRJ wires are excellent but pricy and you wouldnt benefit in performance from them it would be for looks only.
i suggest all gm factory gaskets, i hate felpro and all the other brands of knock off gaskets. ive seen so many of them leak and not hold up. def use the aluminum lower intake gaskets!
yea I'm just going to replace all the gaskets mike
As for the Zzp wires, I already have them with me lol should I just not use them then? Lol
A few more questions:
When I go to replace my trans solenoids will I need a new case seal? Or can I just reuse the original one? I don't think it's plastic is it? Lol I don't remember
Also as far as the AC components, all I need to do is remove the compressor from the motor right? I don't wanna go through disconnecting any lines and then having to refill with freon :/
you dont need to disconnect lines to the ac compressor just unbolt it and push it forward towards the radiator a little and the engine will slide out with the ac lines attached
also just my opinion, i would pull the trans with it. there is a bolt in the back where the trans follows along the engine that bolts the trans to engine and it is a nightmare to get to in the car. also when aligning the trans and engine in the car can be a complete nightmare as well. i did it both ways (pulled engine and left trans and then pulled both and i will pull both every time) its a little more work to get the trans out with it (disconnecting master cylinder, poping axles out of trans and a few other things) you will have to bleed all 4 brakes but its worth it in my opinion.
replace the knock sensors, crank sensor, cam sensor if you can since there easy to get to when the engine is out
you will need a crank pulley puller or you can rent it at advance auto parts or auto zone if you dont wanna buy one.
dont forget gasket sealers, thread lock, thread sealant etc where needed. be sure to use correct torque specs for all bolts.
buy a haynes manual there very helpful for first timers. if you have any questions PM me or message me on FB or even text/call me man ill be glad to help ya. ive only did 5 builds now and no they wern't all on the monte
ive done a L26 sc build, L36 turbo build, L67 turbo build, L67 sc build, L32 sc build lol
o and as far as disconnecting the fuel rails the tool is very cheap but honestly it can be done with your fingers, i have the tool and dont use it i just squeeze the clip with my fingers and pop it off
and as i told you on FB man it sucks to have your baby sitting not running. i know how you feel ive been there twice with turbo monte i wish you the best on getting it running very soon!!!!!
Old Jul 24, 2012 | 03:33 PM
  #67
BlackRainSS's Avatar
At least its coming along! Too bad you couldnt find out how many miles were on the motor.
Old Jul 24, 2012 | 03:49 PM
  #68
I got thinking, if you had the VIN to the car, you MIGHT be able to do a public record search or a CarFax type report and get a "rough" estimate on the mileage (as, at least in my state, mileage gets reported during basic emissions tests and sometimes other intervals).
The coils are the same from the 3100/3400/L36 and L26. The only different coils of this style I know of are the L67 coils. So, no issues running the coils with the engine OR your original ones.
As for the vac lines, check that link I sent you last night from a Bonneville forum of the guy who did a UIM swap, I believe he talks about all that.
It looks like the L26 forged internals varies on year (at least if you can trust Wikipedia).
As for gaskets, GM just puts their name on another vendor's gaskets. I've used the FelPro aluminum gaskets successfully on 3 different 3800s (including my own). Zero issues, it was a great kit each time. I've used Fel-Pro on other jobs without fail. But the MOST important thing said STAY with aluminum gaskets no matter what vendor
Old Jul 24, 2012 | 03:50 PM
  #69
03SSLE's Avatar
Yes, the rockers, retainers, locks and springs need to be removed in order to replace the seals. You will also need a valve spring compressor so you can remove the retainers and locks. Depending on whether or not you remove the heads will determine the type of compressor you need. One style is an 'on car' type that will either be hand held or utilize a stud in the head as a fulcrum point. The other style is a 'C' compressor that has an adjustable clamp and lever to compress the spring. An old trick I use for on car replacement when a compressor isn't available is to feed some nylon rope into the cylinder through the spark plug hole, then rotate the engine to bring the piston to the top of the cylinder. The piston will compress the rope and hold it tight against the heads of the valves and prevent them from falling into the cylinder once the retainers and locks have been removed.
Old Jul 24, 2012 | 03:52 PM
  #70
It's been said in a few places. The biggest thing is the redesigned UIM. It's now aluminum instead of plastic so it doesn't warp and give those problems.
They gave the S3 forged internals starting in 2005, in 2004 it was SUPPOSED to get it on the L26, but Flint didn't make enough of them in time, so only the supercharged S3 got them.
The L26 is also electronic throttle and a returnless fuel system. And the LIM gaskets were the metal ones that we now buy and put on our L36s haha.
They also went through and made emissions even better for the series 3.
The best part though is the redesigned UIM.
