My monte is dead :(
Old Jul 24, 2012 | 06:29 PM
  #81
Originally Posted by trewyn15
what noises was the engine making before? mine makes a ticking type noise when it's cold but it's good when it's warm
The 3.1 and 3.4 are common for lifter tick when cold.
The 3800 is not a common ticker, Frank got some bad luck
And yes Frank, don't overwhelm yourself, the L26 UIM isn't as much work to put on the L26 already lol. That's just all modifications for the L36.
Old Jul 24, 2012 | 06:46 PM
  #82
Crusader SS's Avatar
Man, just read the horrible news, that sucks big time... Glad to hear you're puttin'er back together... Good luck...
Old Jul 24, 2012 | 07:37 PM
  #83
Franks 03SS's Avatar
2011 Monte Of The Year
sucks that your engine went, but once everything is done your monte will be more unique being L26 powered, best of luck to you
Thanks man
Hey Frank, interested in solid rubber W-Body trans and lower engine mounts while you're at this?
I got some for sale..... lol
i wanna buy all my gaskets and stuff first to see where i'm with costs lol how much though?
Originally Posted by 03SSLE
A portion of the radiator is a cooler for the transmission fluid.
The oines from the trans to the radiator are for cooling the trans fluid i believe & sweet link for the intake
ahh ok i never knew that lol see something new i learned already
if you wanted to use it on the l36, not the l26. so you're fine.
ahh ok guys i see, looks like im just going to block off 2 ports on the UIM then. the one on the side and one on top. The vac lines might reach the L36 TB once its bolted on the UIM but idk lol that UIM neck is pretty long :p
we'll see though, thats not to worry about just yet. im going to order the ZZP adapter in a few. now with that adapter.. isnt it going to block off the coolant passages that are on the TB? or is it ported on the other side to keep that coolant passage? also the IAC.... will it still function the way it should with that adapter? lol
and mitch, my motor was still making that ticking noise.. never knew what it was but it must've been bad to blow my motor :p lol
idk if i wanna take it apart anymore to figure out what it is since i have to return it for my core refund :p
thanks man
Old Jul 24, 2012 | 07:47 PM
  #84
im done for today... up next is removing the axles. now john/turbomonte said i can just pry them out of the trans case? i only unbolted my struts from my steering knuckles, hopefully that gives me enough room to pop them out?
i was also wondering if its possible to take out the eng/trans together without having to remove the master cylinder? looks like i would have enough room to wiggle it out, not sure though
Old Jul 24, 2012 | 08:04 PM
  #85
Just go slow and remove what you need to. You got this Frank
Old Jul 24, 2012 | 08:31 PM
  #86
Thanks mike
so any thought on those coolant passages when using the TB adapter? or will it be just fine without them?
Old Jul 24, 2012 | 08:56 PM
  #87
so let me get this straight, i have to do all that modding to the l26 UIM if i want to use it? lol
There are some other ways to go about it, but I think the write up I shared is one of the best. Such as I believe the author of that thread said you could use a valve cover breather to solve the PCV issue.... you could also make a slight change to the vac lines and extend them to the throttle body (instead of all that drilling to the UIM).... leaving just that adapter plate to fit a throttle body. FYI - if you swapped to an L67 T-body, stay with '00 and up (has the MAF hump instead of a MAF bridge). When I did my custom L67 T-body for my Monte, the only reason that T-body to my knowledge REQUIRED re-tuning of the PCM was I diliberately when with a 97-99', removed the MAF bridge (so it's a WIDE open unit) and that changes how the MAF sensor reads the air by altering the inlet.
Now, there were other reasons I needed to have my Monte tuned, but that was the beginning.
Here's a page I talk about my L67 T-body modding:
http://crzyz28.sytes.net/mycars/2004...TB/L67_TB.html
As for those mounts here's the thread I have them posted in (and a lot of other crap I need out of my garage) :
https://montecarloforum.com/forum/pr...ean-out-37360/
I completely agree. The 3800 is a different beast then the 3100/3400. The 3400 is based off the block and design of the 3100 and that 3100 has a slight valve tick and it's normal. Some a tad louder then others, but still.... normal....
Old Jul 24, 2012 | 09:05 PM
  #88
'04 Monte Carlo SS - L67 Throttle Body
I'm going to try and use the ports on the L36 TB, even if i have to extend the lines lol
then i'll just block off the ones on the alum. UIM
i just ordered the ZZP adapter too
so does anyone have any tips on getting those darn axles out? lol
Old Jul 24, 2012 | 09:08 PM
  #89
So now im going to buy all my gaskets for an 05 GP correct?
Old Jul 24, 2012 | 09:20 PM
  #90
Thanks mike
you should be fine without it, I know when I upgrade my TB, you have to bypass that part of the cooling system.
