can you just replace the air filter and get more hp outta your car or..
do ya have to replace the whole system? in other words are there 15 dollars filters out there that would benefit horsepower without getting a kn cold air intake system which is around 200 +
The whole problem with the stock intake systems on most cars is that there are too many bends. The air has to change direction far too many times. the stock air filters aren't terribly restrictive. That's not the issue. It's the turns and restrictions from the intake system between the air filter and the throttle body that makes the CAI systems beneficial. CAIs eliminate those restrictions and present closer to a straight line path between the air filter and the TB. It's actually fairly inexpensive to make you're own CAI or FWI if you know what you're doing to be completely honest.
First it helps if we know what year/drivetrain you are working with. I will assume it's a 2000-2005 Monte Carlo with a 3800? If that is the case, you can search this forum and other 3800 based forums for more details, but here's the quick answers:
- At no cost you can "gut the air box". Basically, open it up, remove some restrictions so more air hits the panel air filter.
- I have a drop-in K&N air filter, which most people recognize K&N as a performance company. I believe that filter off the shelf was $30-$50. So even a "performance" filter, you will spend a little cash for it (beyond $15).
- Some people have removed the air box all together, used PVC pipe from Home Depot and a K&N cone filter to make a "Forced Air Intake".
- The K&N intake you mentioned is NOT a Cold Air Intake. I believe they call it a "Forced Air Intake" and most people call it a "Hot Air Intake". It is the worst design for the money. The air box is not insulated, made of steel (which transfers heat from the engine compartment very well) and where the air tube/snorkel comes thought the box has a HUGE hole allowing heat to bleed in badly as well as no lid! From the get-go, you'd have to insulate the box to help isolate it from heat of the engine. If you were even considering that system, go to ZZP and invest in a Wizaird.
You will notice some performance gain but without additional mods (such as an exhaust, larger throttle body and such), the gains are minimal. I've read a lot of people were happy gutting the air box. That might be the best and cheapest solution.
Let me say this about a CAI system. I had my Intimidator SS for 2 weeks driving it just over 100 miles a day commuting 5 days a week, and getting 22.5 mpg on premium gas. After that 1st 2 weeks, I installed a K&N CAI system, and IMMEDIATELY my mpg rose to 24.5. That was 152,000 miles ago. Do the math. That K&N CAI system has paid for itself MANY times over.
Will it do the same for yours? Is yours supercharged or turbocharged? That's where you will really see the difference. But ANY engine will breathe better and perform better with a CAI, whether it's a store bought unit, or a $40 homemade unit.
Forget about changing the cartridge filter to a K&N lifetime filter, unless you are just after not buying more filters again for your car. Even the cheapest aftermarket freeflowing filter on a pvc or flex' pipe intake will outperform the stock factory intake.
Check your mpg before and after. That's a great indication of how much performance (HP) you just gained.
I think Maniac hit the nail on the head. There are far better designs for your money that will actually keep the air cooler. With the K&N you're essentially paying for name. The only real gains you get are due to the less restrictive flow and you can do that yourself for $40 or so, if that. And doing it yourself it would be very easy to insulate it better and make it better than throwing $250 at the big name.
Originally Posted by joeykl66
my monte is a 2007 ss. is it still that easy? sounds like i need to just invest the 250 and get it done right.
As for a DIY, Jest was recently discussing a Fender Well Intake that is all basically done with stuff from Home Depot and should be rather easy, in expensive and probably as good as a Wizaird in this case. Again, there are options, you just have to research some of them.
ClubGP.com might be another place to go (I know that's where Jester said he got the Fender Well Intake idea he wants to dabble with).
get a cold air inductions CAI. hands down the best one i have ever owned. keeps the intake air temp down. usually only 7-10 degrees higher than ambient temps
Hey I went to ZZperformance and bought theirs it is a true CAI unit it took about a hour to put it lined up real nice and snug. the hardest was squeezing the pcm plugs in and finding the hole on the body clips . there is no drilling or anything. I recommend it highly
1984monte
01-11-2014 04:10 AM
Lastyear07
10-21-2012 04:48 PM
jeffsmonte
06-11-2010 12:48 PM
02Carlo
03-18-2008 04:17 PM
