New had a problem with my monte carlo till now ......when i get outta warranty..
Old Oct 21, 2012 | 03:43 PM
Lastyear07's Avatar
Default New had a problem with my monte carlo till now ......when i get outta warranty..
So I was driving my car last night and out of nowhere my information center displayed... engin hot AC off ...and change engin oil soon ...I just got it changed like a month ago ...I checked all fluids and they seem ok ...my tem.gauge keeps moving to hot ...I'm not good at trouble shooting ...I'm at a lost for words ....any suggestions......should I get get a new car ....
Old Oct 21, 2012 | 03:50 PM
Well for the oil, if you know you had it changed and it still looks clean when you check it, the oil light probably just never got reset. The warm engine, make sure you've got the correct amount of coolant. Has any work been done lately to the cooling system that might have let some air in?
Old Oct 21, 2012 | 03:56 PM
Lastyear07's Avatar
A while back I found out it a a cylinder valve leak but it got fixed at a Chevrolet dealership
Old Oct 21, 2012 | 04:10 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
I am pretty sure that the engine hot/ac off comes from the engine coolant temperature sensor. I replaced mine and the problem went right away. My engine wasn't actually overheating, the car just thought it was. After the code comes on, it can be extremely hard to start if you turn the engine off. That's because it goes into limp home mode. I would recommend using a scanning tool to reset the code before trying to start it. Good luck!
Old Oct 21, 2012 | 04:19 PM
Lastyear07's Avatar
Its starts up fine ...it starts to heat up after about 15-20 of driving ...is it a small fix if its the sensor
Old Oct 21, 2012 | 04:27 PM
It took me five minutes and about $15. If your car is genuinely overheating, it's not the sensor. You have a legitimate problem. I would guess the thermostat.
Old Oct 21, 2012 | 04:33 PM
Lastyear07's Avatar
I smelled something funny while i was driving but its not smoking ..the meter just keeps moving to hot and it said power reduced ...my dad told me it may b a sensor too ...r maybe wat u said
Old Oct 21, 2012 | 04:35 PM
Hmmm... Before my sensor went out, I had a water pump go out. There was very little evidence that there was a problem. Look behind the pulley to your pump while it's running and you may be able to see a very fine spray that doesn't show up when it's not running.
Old Oct 21, 2012 | 04:48 PM
Lastyear07's Avatar
I think ur rite about the thermostat...it has symptoms of it goin bad ...based of sites I'm lookin at
tweek
Mar 27, 2015 10:44 AM
03vaderSS
Aug 23, 2014 05:51 PM
Ricks 2006 SS
Jul 15, 2012 03:53 PM
joeykl66
Jan 10, 2012 03:21 PM
brettmonte
Dec 20, 2010 05:39 PM
