Getting more hp/speed outta my 02 LS
Old Mar 17, 2008 | 11:27 PM
02Carlo's Avatar
Default Getting more hp/speed outta my 02 LS
Okay my car is completely stock.I'm really a novice when it comes to installing anything on my car but I want to know where to start when it comes to getting more hp for my monte?
Old Mar 17, 2008 | 11:49 PM
rysZ34's Avatar
Default RE: Getting more hp/speed outta my 02 LS
cold air intake, exhaust modifications, computer programming...I'ma beginner too, but that is where I would start.
Old Mar 18, 2008 | 07:57 AM
88ss408's Avatar
with out tearing in the motor there is not much you can do
-under drive pully
-ecu reprogram
-cold air intake
-headers
-good exhaust system
it when you start tearing in them thet you can make power
ported heads and intakes bigger throttle body higher compression cam swap
Old Mar 18, 2008 | 04:17 PM
Basic starter mods typically include:
-bigger downpipe (either 2.5" or 3")
-FWI/CAI
-drop in aftermarket pcm
-1.9:1 (or ER) rocker arms
-HV3 intake spacer (www.zzperformance.com)
-colder thermostat/plugs to match other mods
-headers (or pems/plog)
Thats about it for real easy bolt on parts. Once you get beyond that, you start dropping in $/hp gain- or the installs start getting much more difficult (ie heads/cam; boost). Do you ever plan to boost the car w/ a top swap or a turbo? That would also adjust which basic bolt ons you buy.
1984monte
Jan 11, 2014 04:10 AM
Lastyear07
Oct 21, 2012 04:48 PM
BlackRainSS
Jun 18, 2012 10:55 PM
joeykl66
Jan 10, 2012 03:21 PM
jeffsmonte
Jun 11, 2010 12:48 PM
