Traction control button quit working
Just wondering what I could do to replace the traction control button. Hopefully inexpensive and easy to do from my home, I just replaced both front hub bearings trac control button has not worked in 2 months. Any reply helps. Thanks.
check the wires going from the wheel sensors to the abs computer. i had the same problem on my 2002 LS. found out its was a broken wire going to the front wheel sensor. there's u-tube videos on it that are very helpful.
Is the traction and ABS lights active on your instrument cluster? If so, you have an active code ABS code and need a scanner that can read the ABS system. That code will help isolate where the problem is.
By default, your traction system is ALWAYS active (unless you have modified the car with some non-factory changes).
chevygirl24
01-19-2021 12:16 AM
Opinion Needed: Need help 2002 Monte traction control
Jkildea03
12-01-2016 08:03 AM
Opinion Needed: ABS and Trac Control sensors
Musicman217
11-30-2014 09:35 AM
acts121
03-02-2012 09:23 AM
