Traction control button quit working
Old Aug 14, 2019 | 03:20 PM
Jordan Smith's Avatar
Default Traction control button quit working
Just wondering what I could do to replace the traction control button. Hopefully inexpensive and easy to do from my home, I just replaced both front hub bearings trac control button has not worked in 2 months. Any reply helps. Thanks.
Old Aug 14, 2019 | 07:33 PM
Any codes from the BCM or ABS unit?
Old Aug 14, 2019 | 08:01 PM
No codes it just doesn’t come on anymore, I’m wondering if the button/switch needs to be replaced
Old Aug 18, 2019 | 01:22 PM
dlindley's Avatar
check the wires going from the wheel sensors to the abs computer. i had the same problem on my 2002 LS. found out its was a broken wire going to the front wheel sensor. there's u-tube videos on it that are very helpful.
Old Aug 20, 2019 | 10:42 PM
Is the traction and ABS lights active on your instrument cluster? If so, you have an active code ABS code and need a scanner that can read the ABS system. That code will help isolate where the problem is.
By default, your traction system is ALWAYS active (unless you have modified the car with some non-factory changes).
chevygirl24
Jan 19, 2021 12:16 AM
Jkildea03
Dec 1, 2016 08:03 AM
Musicman217
Nov 30, 2014 09:35 AM
acts121
Mar 2, 2012 09:23 AM
atg284
Jan 29, 2010 07:34 PM
