'03 with plastic coolant hose leak??
Old Feb 21, 2013 | 08:31 AM
redfor88's Avatar
Default '03 with plastic coolant hose leak??
Ok had some issues with my SS and the heat going out once last weekend....took to mechanic yesterday to make sure water pump wasnt leaking and thermostat was good but he said I had hoses near back that were plastic and had a leak. They did pressure test and it loses about 3 lbs. Now my question is what and how easy a fix is this????
Old Feb 21, 2013 | 09:28 AM
Red Nightmare's Avatar
its the annoying coolant elbows I'm assuming..
I'm not positive with how difficult the job is, but I do know its recommended to change them out to aluminum. (and add RTV on the gasket ends to prevent future leaks)
Go to your local autoparts store that sells Help!/Dorman parts (Autozone, pepboys, exc..). They may have them readily available or special order for $14. PN# 47065HP
Or places online sells them for around $9 but if you add shipping, its about the same.
Here we go, click this link! https://montecarloforum.com/forum/si...ittings-28491/
Someone in the forum posted a walkthrough. I would reccomend changing that tensioner too at the same time(so you don't do the job again.)
edit: Welcome to the forum btw! And for future reference there are other places in the forum you can post 'help me' threads. the newmembers is more for introducing yourself. The "General Tech" would be a perfect place for a thread like this
Old Feb 21, 2013 | 11:54 AM
I could do the elbow swap in about 30 minutes, then top off and bleed the cooling system. The work is easy, numberous 3800 have thread about this.
Some people have had problems with the plastic dorman elbows (they are like $5 from the parts store). I had some on for a summer, parked and next summer, first ride and they pushed out. I went and spent about $30 for GM elbows. Since then, Dorman also offers aluminum elbows.
Old Feb 23, 2013 | 01:17 PM
redfor88's Avatar
Sorry for putting this in the wrong place I'm still navagating the site....btw I love it!! Anyway those tiny elbows were exactly what was leaking had a hard time finding replacements would love metal one but alas plastic is what I had to use again thanks your help =)
Old Feb 23, 2013 | 02:44 PM
your welcome!
Old May 14, 2013 | 11:57 AM
2002MonteCarlo's Avatar
If you have an Advance Auto parts store around call and ask them. They cost me about $14 for both. HVAC Heater Hose Connector Aluminum Coolant Elbows Dorman 47065HP there is what you need if you call them. It took me all of 30 minutes to do the entire job.
Old May 14, 2013 | 08:40 PM
Welcome to the site. post some pics when you can.
Old May 14, 2013 | 08:48 PM
Glad you got it fixed.,My wife's Impala SS had the coolant elbow break monday..
So I had to fix that.. I got the metal ones..I got an extra set for my Monte..
I'll have to do mine sometime..
GSP1120
Dec 12, 2014 04:57 PM
robz
Nov 14, 2013 10:53 PM
milrlyt
Jun 18, 2011 02:12 PM
GMAK907
Dec 2, 2009 03:31 AM
jay26
Jun 9, 2009 05:02 PM
