trac off ?????????????????????????????????
Old May 20, 2010 | 05:57 AM
  #31
Xx-007-xX's Avatar
Exclamation
Hmmmmm it did it again this morning when my wife started to leave for work, i told her to shut the car off and turn it back on and it stopped doing it.
Old May 20, 2010 | 03:17 PM
  #32
Pure2sin's Avatar
This might sound obvious but, have you checked the break pads? I was thinking that could account for grinding and the loss of break power. The ABS, Trac, ect. problem could be unrelated. Otherwise if you have plenty of pad I would do the other things I mentioned and then try to diagnose if it is a wheel bearing or not.
Old May 21, 2010 | 02:32 PM
  #33
OhKay's Avatar
I also had some incidents of "break slipping," usually pulling into parking spots or slowing at turns. Since you also have break involvement, and f your pads are fine, you may be having a problem with your ABS control unit like me, or a short in the wiring harness.
I'm not a pro, but just recommending you check this out (before spending a bundle on other stuff like me) based on my experience, and because freaky break s* is scary.
Old May 22, 2010 | 08:54 AM
  #34
Xx-007-xX's Avatar
Post
I am going to check it out today, I wouldn't even know where to start looking for the short if there is one, for now I am going to check the connections and check for play in the hubs,
Old May 22, 2010 | 12:03 PM
  #35
Xx-007-xX's Avatar
Exclamation
Got it up on jacks today and there is play in both front wheels/hubs, I grabbed the tire at the top and bottom and wiggled it and it was loose. I would say that the top of the tire would work back and forth about 3/32 of an inch, is there a certain amount that it CAN move that is with in safe standards or do I need to change my hubs? could this be the cause of my problems of the "service traction/trac off/ ABS" light coming on sporadically?
I am going to repost a new thread about this.
ladagosta
Aug 24, 2012 09:54 AM
ChibiBlackSheep
Aug 19, 2009 10:53 AM
amberblk00
Aug 7, 2008 12:16 PM
willie8701
Mar 10, 2008 12:02 PM
Gr4v3_7
Oct 12, 2007 08:07 PM
