"Trac Off"
Old Jul 10, 2008 | 04:59 PM
amberblk00's Avatar
Default "Trac Off"
I have a 2000 ss and the "trac off" just recently came on and will not go off. does anyone have any suggestions?
xoxo
Amber
Old Jul 10, 2008 | 07:04 PM
kweef's Avatar
Default RE: "Trac Off"
well is the light just on or is the traction actually off...just try to squeel the tires and c if it stops u lol
Old Jul 11, 2008 | 04:35 PM
88ss408's Avatar
i have a 03 impala (the 4 door monte LOL) and my trac light comes on all the time and it's because the abs senser on the wheel bearing F&^% all the time
you should check to see ifthe 2 little wires are still atached or broken or somthing
Old Jul 12, 2008 | 10:51 AM
kweef's Avatar
actually this happened to me last nite...we replaced my rotors and brake pads and when we bled the brakes we did not tighten the vent enough and brake fluid was leaking out, this casued my low brake fluid light to come on and my trac off light came on...so check the level of ur brake fluid
Old Jul 23, 2008 | 05:38 PM
04 Intimidator's Avatar
Also try disconnecting the battery for 20 min.
Old Aug 7, 2008 | 12:16 PM
jeffsmonte's Avatar
I had this problem a few years back, brought it to the cealer to get checked and it ended being a serious electrical system problem! Id get it checked, plus I couldnt imagine its safe having it off all the time.
teamfbody
34
Aug 11, 2013 08:22 PM
peoples 01 ss
May 22, 2010 12:03 PM
ChibiBlackSheep
Aug 19, 2009 10:53 AM
willie8701
Mar 10, 2008 12:02 PM
Gr4v3_7
Oct 12, 2007 08:07 PM
