Temp Gauge Doesnt Move - Fan Staying On - PLEASE Help
Old Apr 4, 2010 | 04:47 PM
peoples 01 ss's Avatar
sorry bout that reply, tryin to start a new thread
Old Dec 16, 2012 | 06:08 PM
CityLifeSS's Avatar
Having this same problem now gauge not working n fan runs adter the cars off. Noticed it yesterday...it aways blew hot. Thanks 4 the help
Old Dec 16, 2012 | 06:13 PM
CityLifeSS's Avatar
Question did the car still blow hot after u replaced this?
Old Dec 18, 2012 | 06:55 AM
pilot2411's Avatar
probable cause to the grinding while turning is a wheel bearing. the wheel bearings have the speed sensors installed in them, and the sensor wire could be broken. this wire isnt under the dash. please, for petes sake, do go rootin around with those wires. have your vehicle checked by a good shop.
Old Mar 19, 2013 | 12:16 AM
edj1949's Avatar
I've done all of the things on my monte carlo to get the temp gauge to work and finally figure out that all I had to do was add more anti freeze to the radiator, it looked full but I took the cap off and started the engine and as the water went down I added more to it till it was full and replaced the cap then I reset the computer and I haven't had a problem since, so save yourself some money and work and try this first cause after you replaced everything what do you normally do ADD MORE ANTI FREEZE so was the thermostat or sensor bad or not if everything is working ?????
mhol1908
Mar 9, 2013 06:23 PM
JWCCR
Nov 29, 2010 01:27 AM
NewFoundJoey
May 14, 2009 07:39 AM
Zeronx
Sep 12, 2007 08:51 PM
ginasmontecarlo
Jan 27, 2006 03:40 PM
