Temp Gauge, rad fan , A/C issue
Old Dec 28, 2005 | 10:08 PM
ginasmontecarlo's Avatar
Default Temp Gauge, rad fan , A/C issue
I have a 2000 SS. The cooling fan stays on for awhile after shut-down, the temp gauge quit working and the A/C won't work. This all happened at one time, and then started working properly for a week, now they quit agaain. Any ideas?
Old Dec 29, 2005 | 10:25 AM
montejass's Avatar
Default RE: Temp Gauge, rad fan , A/C issue
Sounds as if you may have a temp sensor problem. R&R..
Where in south Texas are you??? If your in Htown or the area I can pull codes for you, or, run it to Twilight Zone (Auto Zone) and have them pull DTC codes for ya.
TVW
Old Jan 18, 2006 | 04:01 PM
Billdo's Avatar
montejass,
I am in Houston, and have 2000 SS. I am having the same problem. Also the Check engine light came on this morning. Started 1 day after turning 90k....
Billdo
Old Jan 20, 2006 | 08:43 PM
bpick32's Avatar
Im having the same sort of issue myself. Check this out.
Recently i started having some problems with my monte shifting very hard while i was driving. When i checked the car out at the time, the radiator fluid was low. So i Flushed it throughly and refilled it with the DEX-COOL fluid that the vehicle came with when i bought it a year ago. All was fine. Though i thought! A few weeks later the vehicle started to act up again, doing the same thing as b4. So i checked everything again. This time the fluids where at there normal levels. Once i finished checking everything, i started the car back up and drove it around. Too my surprise, the problem seemed to go away. I started monitoring the temperature guage in the car while i was driving around, and noticed that it was getting slightly high. Not high enough to cause an alarm, but noticed it was staying slightly higher than i had noticed b4. Keep in mind that when i flushed the system b4, i changed the thermostat as well. Then the strangest thing started happening. It recently started getting a little cold here, and im have to turn the heater on to warmup. I noticed that the drivers side climate doesnt blow hot air. Only cold air no matter what. The passenger side blows as it should and adjusts to the proper climate that i choose. After riding around for awhile with heater on, i notice the vehicle starts shifting hard again. I then turn off the AC completely. It still shifts hard. I then stop the vehicle turn the car off. Since the there is a doom light delay upon exiting the vehicle, i then open the door and close it to rest everything, and wait for the headlights to go out. Once the headlights go out i start the car back up and start driving. The car is back too shifting normal now. Since i've noitced that it happens when i have the AC or HEATER on, i have been drinving around with none of that on now and the car drives fine. But i still notice that the temp guage is still showing the car getting hot. On top of that, i notice that b4 ALL of this started, i use to be able to hear the cooling fans running even when i was standing outside the car. Now i notice that i can barely hear them at all. And when it does come on, BOTH fans come on for about a couple of seconds and then go off. I've sat there and watched them come on and they come on. I dont know what else too do. PLEASE HELP!!!!
Old Jan 27, 2006 | 03:40 PM
montejass's Avatar
The electrical system on these cars can get tempermental.
Sounds like a sensor problem to me, I would run it over to Twilight Zone and have them check codes.
bigdomvegas
Mar 19, 2013 12:16 AM
Jsc00ter
Mar 8, 2013 10:04 AM
JWCCR
Nov 29, 2010 01:27 AM
biggriggs
Sep 30, 2008 06:48 PM
smolek37k
Dec 1, 2007 07:08 PM
