Temp Gauge Doesnt Move - Fan Staying On - PLEASE Help
Old Dec 30, 2009 | 12:53 PM
MAMONTE's Avatar
I know its late for this post, but just for everyone's reference if they stumble across this thread...
My 06 3.5L was doing the exact samething, replaced the T-stat, and problem fixed. It really seems like a huge problem, because everything just goes crazy, but all it takes is a new t-stat, and EVERYTHING starts functioning properly.
Old Mar 17, 2010 | 05:07 PM
01mightycss's Avatar
hey, mc lovers
im new here and I have all types of lights on my vehicle, Ive read all of the posts pertaining to my problems. I hope and think the posts r correct. My traction and abs lights are on. Im also about to change my plugs and wires ....01 monte ss..Ill post my results.
Old Mar 17, 2010 | 05:39 PM
monte07's Avatar
i allways had the habbit when ever the thermostat was out i always took advantege on doing a flush so i lnow every thing is clean inside the water gernals
Old Mar 17, 2010 | 05:40 PM
monte07's Avatar
oh to your answer 01mightycss one of your wheel beaings hubs is going bad it is hard top tell wich one but have a scan done on it to tell wich one it is
Old Mar 18, 2010 | 02:07 PM
Red face
Just finished my plugs & wires ,back 3 took 47minutes ,Thanks to all of u. I did roll the engine that made it simple. Now I'm starting the thermastat .update later
Old Mar 29, 2010 | 11:49 PM
lostcausenjtown's Avatar
I hope you guys are right about that thermostat thing. However, my fan/fans are very loud like something is stuck in there. Any idea what that may be. I was at the stop light and heard a loud noise. Turns out it is coming from the fan. Do they go bad. I just had a new radiator and water pump installed(by me of course). Any help would be appreciated.
Old Mar 30, 2010 | 01:46 PM
Default look for my pics also
Changed thermastat ,now everything works as they should. Fan noise is gone and heat is too hot, guage works perfectly. Wheel hub check was done but traction/ads lights are still on. I also replacedvmy fender got pics.
Old Apr 1, 2010 | 01:46 AM
Jmoney52's Avatar
01mightycss u should get your brakes checked maybe thats the problem.....On my 2000 Monte SS my traction off light and parking brake light was on when I drove and I took it to a shop and they said I needed all new brakes rotors and everything.After I got them the lights went off so see if thats the issue
Old Apr 4, 2010 | 04:35 PM
peoples 01 ss's Avatar
Wd40 will help a loud fan, I sprayed mine when the sound was loud like it was stuck and now back to sounding normal
Old Apr 4, 2010 | 04:43 PM
Default Traction control problem
What up fam
in my 01monte my traction control keeps turning off while driving. Ever since I've had the car it seems like when I'm turning at low speeds I hear a grinding sound and the trac off light comes on and usually gos off soon after. Is there a wire under the steering colum that could be gettin pulled or is it a different problem alltogether?
Please help afraid to hurt my baby lol
