smell and jerk
If the wires are good and the plug is too then you have either a bad injector or wire harness, burnt valve seat, collapsed lifter, broken valve spring, or a mechanical failure of the piston or rings. I doubt it's one of the these or it would make a ton of noise besides the misfire. The injector should be easy to detect using a mechanics stethoscope. Listen to the other injectors and then see if the questionable cyl makes the same sound. My bet is the wire or plug is faulty and you've missed something....
No offense to your diag work.
brandonmac000
19
04-09-2011 09:54 PM
NYGiantsfan
09-11-2010 01:57 AM
