smell and jerk
Old May 9, 2011 | 12:41 PM
mcfogerty's Avatar
Default smell and jerk
Our car has a smell to it and jerks when we drive it. anyone know what this could be ?
Old May 9, 2011 | 12:48 PM
whiteonwhite's Avatar
Your Catalytic Converter mite be clogged if it smells like Egg thats it!
Old May 9, 2011 | 12:52 PM
Enzo354's Avatar
STILL SLOW
Check for vacuum leaks, normally that will do it.
Couldn't have thought of a better thread name? XD
Old May 9, 2011 | 12:58 PM
nitehawkjcb's Avatar
x2 on the cat
Old May 9, 2011 | 07:05 PM
mcfogerty's Avatar
The computer reading states that the 3rd piston is misfiring. plug wire and coil are all good.
Old May 9, 2011 | 09:36 PM
Justin Knight's Avatar
If the wires are good and the plug is too then you have either a bad injector or wire harness, burnt valve seat, collapsed lifter, broken valve spring, or a mechanical failure of the piston or rings. I doubt it's one of the these or it would make a ton of noise besides the misfire. The injector should be easy to detect using a mechanics stethoscope. Listen to the other injectors and then see if the questionable cyl makes the same sound. My bet is the wire or plug is faulty and you've missed something....
No offense to your diag work.
Old May 11, 2011 | 09:47 AM
What does it smell like?
Old May 15, 2011 | 08:51 AM
mcfogerty's Avatar
It was the wire . Thanks for the help.
Old May 15, 2011 | 08:52 AM
mcfogerty's Avatar
It was the wire. Thanks for the help.
sdowney
24
Oct 10, 2017 12:20 AM
rgjr702
Apr 18, 2013 07:41 PM
brandonmac000
19
Apr 9, 2011 09:54 PM
NYGiantsfan
Sep 11, 2010 01:57 AM
jeffsmonte
Oct 24, 2008 10:18 PM
