some jerk stole my antenna off my back window
Old Sep 9, 2010 | 04:25 AM
NYGiantsfan's Avatar
Thumbs down some jerk stole my antenna off my back window
i have an 02 ss with the onstar factory amp package i had a stick on antenna that someone took ..i went to part stores all over they all have the same garbage just for show antennas im guessing its an amplified antenna since i remember it was a lil heavy and theres a lil modulator inside behind where it gets stuck on tried junkyards no luck they want to sell me the entire wiring system with it....has anyone ran into this issue, or know where i can get the same one with out paying 50$ to the dealer... thanks
Old Sep 9, 2010 | 10:36 AM
Since OnStar switched to digital in 05, your antenna doesn't work anymore. For OnStar to work you would have to take your car to the dealer and get your system converted to digital.
Old Sep 10, 2010 | 12:04 AM
Well im not really looking to use it i disconnected it i need it for the radio i have poor reception
Old Sep 10, 2010 | 09:21 PM
The FM antenna is built into the back glass - it has nothing to do with the black OnStar antenna on the out side of the back glass. Does your rear defrosters work? Maybe the wires were cut by a razor blade or something?
Old Sep 10, 2010 | 09:43 PM
Jomao_o's Avatar
Yeah i was just gonna say that.
My antenna fell off, after i washed the car, the glue or w/e it was coming off and it finally did, it was leaning so i decided to remove it.
It has NOT affected reception not ONE BIT, i do miss it because i was gonna put one of them NFL mini helmets on there.
Old Sep 11, 2010 | 01:57 AM
There also could be a problem at the back of the radio where the FM wire plugs into it.
jeffsmonte
Nov 21, 2022 07:34 AM
NYGiantsfan
Jan 24, 2011 12:43 PM
jeffsmonte
Oct 24, 2008 10:18 PM
rcohen
Feb 13, 2007 10:12 AM
rrobert05
Jul 5, 2006 12:03 AM
