Slow heater issue?
Old Feb 29, 2012 | 02:58 PM
djtiny's Avatar
Default Slow heater issue?
Hey everyone, sorry if this is in the wrong section!
I just got an '06 Monte Carlo LT, and I have noticed that when using the heat, the blower works fine, however the air will not get warm unless the car has been running for a while and usually never when idling.
AC works fine however.
I have seen some similar stories on here but can't seem to find a solution. I have heard it could be the thermostat, is that the true?
Old Feb 29, 2012 | 03:21 PM
Yes it could be the thermostat, could also be air stuck in the system, but I don't believe your car has a proper bleeder valve
Old Mar 4, 2012 | 03:35 PM
ratbuddy's Avatar
Mine doesn't blow warm air unless the RPMs are above 1500 or so. I also hear a gurgling noise from the dash. I think it's what chibi said, air stuck in the system.
If you let the can run until the temp gauge hits normal, then rev the engine up to 2k or so, does the air suddenly turn warm?
menaja19
18
Dec 6, 2007 10:43 PM
ffriccio
Jun 30, 2007 09:39 PM
CoolDad64
Mar 14, 2007 02:46 PM
86monte818
Jul 8, 2006 03:20 AM
Cainius
Jan 3, 2006 04:31 AM
