revving type noise when driving car
Old Mar 30, 2009 | 11:53 AM
bigblack3's Avatar
Default revving type noise when driving car
i have a 2001 monte ls 3400. when i am driving the car it makes a revving typ noise secondary to the normal sound when accelerating. it shifts ok so i dont think its the tranny. it almost sounds like it is tied to a pulley somehow. could it be a uv joint? the serpentine belt is new.when car is in gear and i put it in neutral and hit the pedal it makes the nois as well. but not when the car is parked?? please help i am baffled???
Old Mar 30, 2009 | 01:20 PM
mrl390's Avatar
Is it a whining noise you are hearing? Not quite sure what you mean by reving noise.
Old Mar 30, 2009 | 02:39 PM
bigblack3's Avatar
its not like a belt whining noise but more of a humming type noise
Old Mar 30, 2009 | 03:33 PM
anything hindering performance? or just a noise?
Old Mar 31, 2009 | 10:23 AM
bigblack3's Avatar
it seems to lag a bit
Old Mar 31, 2009 | 10:37 AM
kweef's Avatar
well considering it does it when you not driving then i doubt its the u-joint. how long ago did u replace the belt? the new belt will b alot tighter than the old one and the pulleys may not be used to the extra pressure. did u spray some lube on the pulleys when u replaced it?
Old Mar 31, 2009 | 10:40 AM
bigblack3's Avatar
it only does it when i am driving. or when i am driving and i put it neutral it still does it as well? belt seems tight
Old Mar 31, 2009 | 01:20 PM
bigblack3's Avatar
it has 62000 miles
Old Apr 1, 2009 | 01:26 PM
bigblack3's Avatar
would lag mean anything?
Blindmelonade
Sep 5, 2014 01:21 PM
ecosta221
Mar 10, 2014 09:53 PM
Crusader SS
15
Jan 27, 2011 04:43 PM
southerncash
Feb 28, 2010 12:47 PM
Shasta
Jun 10, 2009 12:53 PM
