Pressure for Bias Tires
I recently purchased an '82 that had been sitting since 1994. It had a set of radials on it but they were pretty scary looking so I replaced it with a new set. However these new tires are bias. The manual and door sticker instruct to inflate tires to 35 psi, however the maximum pressure recommended on the the tire is also 35 psi.
Do people think that the pressure recommended on the tire is making allowance for the fact that if inflated "cold" to 35 psi, it will be rising above that during use? Or should I cold inflate to a lower pressure?
Tire Pressure On Tire - Ask.com
www.ask.com/Tire+Pressure+On+Tire
Explore Tire Pressure On Tire. Get Answers Now on Ask.com.
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
Click above & explore.
What is the name brand & size of the tires you purchased ?
Type the name of your tire into your search engine & it should give your the tire company...Most have a contact link...I would then call them & ask.., or you could also call your local tires shops & ask...
We need more infor on your tires to help...
Good Luck...
Oh, I would not run them @ max
![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
They are Shell Comfort Ride II, sized P195/75B14. They are quite possibly older than the car itself. I bought them NOS from a guy who had many in storage. They seem to be doing fine.
I had to put the car up on blocks soon after the OP; I was busy with school/work. However it is back down now.
joe111599
06-10-2016 07:01 PM
ecosta221
11-13-2013 04:05 PM
Randy Biron
07-14-2012 08:07 PM
