Pressure for Bias Tires
Old Aug 11, 2013 | 11:48 AM
Puska 35.M's Avatar
Default Pressure for Bias Tires
I recently purchased an '82 that had been sitting since 1994. It had a set of radials on it but they were pretty scary looking so I replaced it with a new set. However these new tires are bias. The manual and door sticker instruct to inflate tires to 35 psi, however the maximum pressure recommended on the the tire is also 35 psi.
Do people think that the pressure recommended on the tire is making allowance for the fact that if inflated "cold" to 35 psi, it will be rising above that during use? Or should I cold inflate to a lower pressure?
Old Aug 11, 2013 | 01:26 PM
I would cold inflate lower and keep an ey on how they wear. If the max is 35 that would be dangerous
Old Aug 11, 2013 | 09:30 PM
Puska 35.M's Avatar
I have them at 30 right now.
Old Aug 12, 2013 | 07:49 AM
Tire Pressure On Tire - Ask.com‎
www.ask.com/Tire+Pressure+On+Tire
Explore Tire Pressure On Tire. Get Answers Now on Ask.com.‎
Click above & explore.
What is the name brand & size of the tires you purchased ?
Type the name of your tire into your search engine & it should give your the tire company...Most have a contact link...I would then call them & ask.., or you could also call your local tires shops & ask...
We need more infor on your tires to help...
Good Luck...
Oh, I would not run them @ max
Old Aug 28, 2013 | 10:47 PM
iceman5's Avatar
I believe my door sticker on my 70SS states 24psi for the bias, but that seemed too low. I typically run between 30 and 32.
Old Aug 29, 2013 | 02:09 AM
between 28 and 32psi is the recommended pressure for a bias ply tire depending on the size of the tires.
Old Jun 9, 2015 | 09:55 AM
Puska 35.M's Avatar
They are Shell Comfort Ride II, sized P195/75B14. They are quite possibly older than the car itself. I bought them NOS from a guy who had many in storage. They seem to be doing fine.
I had to put the car up on blocks soon after the OP; I was busy with school/work. However it is back down now.
joe111599
Jun 10, 2016 07:01 PM
ecosta221
Nov 13, 2013 04:05 PM
GoodZwell
Feb 21, 2013 08:22 AM
Randy Biron
Jul 14, 2012 08:07 PM
turner_dtp
Oct 28, 2008 09:37 PM
