Info: Power steering pump help
Old Apr 18, 2019 | 09:41 AM
Wayne Everlasting's Avatar
Default Power steering pump help
2000 Monte Carlo power steering pump it’s new but still makkin da whining Noise I got it fix 3 days ago and the shop told me the noise would stop after a couple of day but it’s been like this ever day sents I got da car bck any help ...
Old Apr 18, 2019 | 12:33 PM
I wouldn't touch it - take it back to the shop that fixed it. Certainly they've got some kind of warranty behind their parts and work?
Old Apr 20, 2019 | 09:07 PM
O-Five's Avatar
Sounds like air is trapped in lines or low on fluid. Check the fluid level on level ground, if low you can tell them so and make them feel incompetent. Old school trick, take a spray bottle filled with water. Spray it on the power steering belt while the car is running (prepare for possible shower). If the squealing goes away the problem is with the belt slipping, glazed etc. If it continues to squeal then it is internal with the pump issue. Works the same on a squealing alternator, is it a belt or bearing as the water cannot reach a sealed bearing to quiet it down.
TomF106SS
Mar 16, 2015 11:03 AM
02paceSS
May 11, 2014 02:55 PM
brettmonte
Apr 7, 2011 02:57 PM
07MonteMadness
Mar 23, 2011 09:01 AM
Absolutpolack
Aug 16, 2010 08:00 PM
