Engine + Steering whine
Old Mar 22, 2011 | 03:24 PM
07MonteMadness's Avatar
Default Engine + Steering whine
Hey Y'all!
New to this forum (well sort of, you helped me out several years back when I had an issue with my '03)
I just developed a whine that is centered around the top portion of the serpentine pulley area. It happens at idle and while driving, increasing its sounds when the RPM increases. When I started the car today, I noticed the power steering is whining as well. It is loudest at startup while cold.
I do not drive the car alot (thankfully). I drive at most 500 mls/month. I do however, have the tendency to forget things like checking levels.
I checked the power steering resevior and it was low, but I have to go get some fluid. However, it makes me nervous that it just may not be the power steering.
Thoughts? suggestions?
Thank you!
Old Mar 22, 2011 | 05:34 PM
mrl390's Avatar
If its not the power steering its probably either the alternator or idler pully. My idler pully squeaked for a few months before walking off the bearing and shooting the belt onto the highway at 55 mph.
Old Mar 22, 2011 | 07:17 PM
If you take the belt off and spin everything you might be able to see what is making the noise if it isn't the PS fluid
Did you ever have the recall work done on the PS system??
Old Mar 23, 2011 | 07:43 AM
MAMONTE's Avatar
I would almost bet money its the power steering pump. Its very common on these cars, and if yours is low on fluid, all the more reason to think its that. Add fluid and see if that does anything for you. If not, you'll probably be looking at replacing the power steering pump soon.
Old Mar 23, 2011 | 08:46 AM
TheMonteMan's Avatar
idk if there was a recall on all the motors but the ls4 cars had a recall on the power steering cooler line. i wouldnt try and take the belt off if its the ls4. its supposed to be a huge pain and require a special tool.
Old Mar 23, 2011 | 09:01 AM
MAMONTE's Avatar
Yes, the recall on the power steering was for all engines.
TomF106SS
Mar 16, 2015 11:03 AM
03SSChevyFun
Nov 21, 2010 07:12 PM
Coors
Mar 5, 2009 09:03 PM
kweef
Jan 6, 2009 11:35 AM
cain45
Aug 20, 2007 08:57 AM
