Motor Mount
Old Aug 14, 2014 | 10:09 AM
woodr004's Avatar
Default Motor Mount
Does anyone know which motor mount I need to use when I drop a 2005 Impala 3400 engine into a 1997 MC that had a 3100? I got an Anchor mount like the 3100 had and it does not fit the 3400. I am worried that the 3400 mount might not fit the frame. I did not get a old mount with new engine. I thought I would ask before I run out and buy another motor mount.
Thanks
Pat
Old Aug 14, 2014 | 11:59 AM
To my knowledge, you should be able to pull the mounts off the 3100 and they will bolt up directly to the 3400.
Old Aug 14, 2014 | 12:10 PM
The 3100 and 3400 blocks are virtually identical. You shouldn't have an issue by using the 3100 mounts that are currently on the car.
Old Aug 14, 2014 | 02:58 PM
I just looked up the mounts and they all cross reference the same for your monte and the car you got the 3400 from. So should not be any firmest issues. Are you able to post any pics of what you are working with??
Old Aug 15, 2014 | 08:03 AM
woodr004's Avatar
Default Solved
Thank you all, I went back and looked at the 3100 and took the bracket off, that was my problem. I felt kind of red faced, but I am learning.
Pat
Old Aug 15, 2014 | 09:13 AM
vikesfan's Avatar
we all hard to start learning somewhere.
what part of MN?
Old Aug 16, 2014 | 08:18 AM
woodr004's Avatar
Default Elk River
Elk River between the Cities and St. Cloud
Old Aug 18, 2014 | 09:48 AM
vikesfan's Avatar
ahh, im in delano, i have a buddy that lives up in ER.
Old Aug 18, 2014 | 10:04 AM
woodr004's Avatar
Default un related fuel question
When looking at the injector rail, what are the injector positions?
Pat
2003supersport
21
Apr 29, 2009 02:06 PM
2003supersport
Feb 4, 2009 09:15 AM
HyperFox
FWD Tech Guides '95-'07
14
Nov 7, 2008 12:18 AM
odessadude
Feb 2, 2008 07:23 PM
GooberMT
24
Sep 26, 2007 09:06 PM
