A LOUD whinning sound when I drive! Whyyyyyyyyyyyyyy!
Old Jul 3, 2009 | 04:40 PM
rgant_19's Avatar
Default A LOUD whinning sound when I drive! Whyyyyyyyyyyyyyy!
I have a 01 Monte Carlo Ss. In chicago, there are what is called "speed humps" on the residential streets (blocks and alley ways) as you drive. Its mainly to slow down traffic while driving down a neighborhood black. While driving, I didn't notice that the alley had a speed hump and I drove over it pretty fast. After I noticed that I had done it, I slowed down and heard a whinning sound from underneath my car everytime I make a turn or drive. From that point of last week (as when it happened), it has still be sounding that way. I am guessing that i have triggered my power steering pump to go bad, maybe its my rack-a-pinion. I did check my fluid level and I topped it off, but the sound still remains kinda loud. Any suggestions, please help!
Old Jul 9, 2009 | 08:42 AM
MAMONTE's Avatar
I would say its your power steering pump if it is related to RPM's...does the noise get louder with more RPM's?
It may also be a bad wheel bearing if it is more speed related...in other words, if it does not make the noise more or less due to the RPM of the engine, but tends to make the noise the most at certain driving speeds, it may be a wheel bearing...
My first guess is power steering pump.
Old Jul 18, 2009 | 06:32 PM
rgant_19's Avatar
What the problem (for now) was the power steering rezzzzz was very low. Which I don't understand at all because after hitting the bump that I have driven over, the steering became loud. After replacing the fluid, then thats when it calmed down. I still think there is something wrong with my steering (which its veering off too the right still) while I am driving.
Old Jul 19, 2009 | 01:39 AM
MAMONTE's Avatar
Hmmmm i'd get a four wheel alignment, and see what that does.
Old Jul 19, 2009 | 02:51 AM
rgant_19's Avatar
I already got the alignment back like 2-3 months ago (under warranty). For ALL tires! I will just go back and get them to check it again to see what the problem is instead of guessing.
Old Jul 19, 2009 | 01:24 PM
MAMONTE's Avatar
Good idea... they should be able to figure it out!
Old Jul 19, 2009 | 03:26 PM
MonteDriver's Avatar
Try cycling the A/C and see if that changes it, then i would try dry steering and see if that changes anything.
Try in park as well and see if its any different in neutral, park or driving.
When you went over the hump did you scrape? if so you may have hit the tranny, cat or resonator and could be exhaust hanger went missing or something.
Old Jul 20, 2009 | 12:48 AM
rgant_19's Avatar
I didn't even bother to look for none of those possibilities that yon've mention MonteDriver. I will though! That is a good idea to move the steering in place instead of the car always being in motion.
Old Jul 20, 2009 | 02:19 AM
moonlitmagik's Avatar
if it's veering, it's your alignment. Get that redone and that will stop the veering issue. Check your exhaust hangers, your tranny pan, oil pan anything underneath could have scraped and or ripped off.
Hope this helps.
Joe Bloggs
Sep 10, 2011 12:07 PM
DJTJ
Jun 14, 2011 08:40 AM
MAMONTE
Sep 22, 2009 06:01 PM
MAMONTE
May 16, 2009 06:02 PM
