6th Gen ('00-'05): How do I Fix my A/C ?
Old May 14, 2016 | 11:49 AM
Kooni Holmes's Avatar
Default How do I Fix my A/C ?
It blows strong and it only blows HOT and the vented air blowing thru? What might be the problem for it not to blow Cold Air?
Old May 14, 2016 | 11:58 AM
Thumbs up Welcome to the MCF
What year is your Monte Carlo ?
Check the below links & explore to see if the information helps you ? Your A/C may need charged or serviced by a A/C tech. Good Luck
montecarloforum.com
montecarloforum.com/forum/monte.../c-light-flashing-06-a-13763/
May 19, 2009 ... Has anyone else had this problem before. My A/C light just flashes for a few seconds after I push it in and the A/C doesn't work. Anyone else ...
montecarloforum.com
montecarloforum.com
montecarloforum.com/.../2004-monte-carlo-ss-c-problems-15438/
Aug 18, 2009 ... Hi everyone, im new here but perhaps someone out there has the same problem or has fixed it. I have a 04 Monte SS 3.8L. I think that the vent ...
montecarloforum.com
montecarloforum.com
montecarloforum.com/...9/2000-monte-carlo-c-problem-30100/
Aug 7, 2011 ... i thought i would share a problem with the fix. i have dual climate control & have cold air on passenger & warm air on drivers side.if i raise.
montecarloforum.com
montecarloforum.com
montecarloforum.com/.../95-chevy-monte-carlo-ls-problem-c-689/
Jul 30, 2005 ... But I have a weird issue involving the A/C. On the driver's side I can feel cool air coming through within' about maybe 10-15 minutes of starting ...
montecarloforum.com
montecarloforum.com
montecarloforum.com/.../2001-monte-carlo-ss-c-not-working-27723/
Apr 23, 2011 ... It's very possible that you're having problems with the A/C Controller. The part that the Temp. controls, Fan speed, and air direction comes out in ...
montecarloforum.com
montecarloforum.com
montecarloforum.com/forum/monte-carlo...8/c-problems-49594/
Jul 13, 2014 ... My 2000 Monte Carlo SS 3.8 ac is not blowing air. I feel the cool air coming on but the blower is not coming on and also my display atop of my ...
montecarloforum.com
montecarloforum.com
montecarloforum.com/.../replaced-iat-sensor-fixed-my-ac-problems-50939/
Nov 3, 2014 ... I've been having A/C issues with my car ever since I bought it 3 months ago...it's been sporadic at best! It would sometimes worked in highways ...
montecarloforum.com
montecarloforum.com
montecarloforum.com/...performance.../06-ss-ac-problems-28622/
Jun 2, 2011 ... its so weird, the compressor comes on , then off. but it works fine when the car is moving, but when i stop a a light or have it in park, it blows hot.
montecarloforum.com
montecarloforum.com
montecarloforum.com/forum/monte.../2000-mc-c-problem-19895/
Apr 8, 2010 ... a/c cools great in city or short drives (60 miles or less). any distance over this it quits cooling. i am almost sure it is freezing up. it has.
montecarloforum.com
montecarloforum.com
montecarloforum.com/.../c-problems-perhaps-stemming-electrical-short-2088 /
Aug 16, 2006 ... Ok, I figure I'll give you all the info I have on this to make sure It's as helpful as possible, please forgive if there is information you do not.
montecarloforum.com
Old May 14, 2016 | 11:00 PM
nitehawkjcb's Avatar
It might need a charge, therefore it could be leaking. Compressor could be a culprit as well.
