A/C light flashing on 06'
Old May 19, 2009 | 11:14 PM
S_DAHM's Avatar
Default A/C light flashing on 06'
Has anyone else had this problem before. My A/C light just flashes for a few seconds after I push it in and the A/C doesn't work. Anyone else have this problem or know what it could be?
Old May 20, 2009 | 12:53 AM
bwill314's Avatar
Yes, I have this problem too, but it only happened a few times. I couldn't get it to do it for the dealer so they couldn't tell me anything.
Does anyone know why these cars are having this problem??? I have an 06 SS
Old May 20, 2009 | 06:08 AM
bowtietech's Avatar
Might want to consider finding a new dealer. Information on issues like this are right at the dealers fingertips. Here is a list of all the possible causes of the A/C LED flashing on the A/C button..........
• The throttle position is 100 percent.
• The A/C pressure is more than 3034 kPa (440 psi).
• The A/C pressure is less than 241 kPa (35 psi).
• The engine coolant temperature (ECT) is more than 124°C (255°F).
• The engine speed is more than 5480 RPM for at least 409 seconds.
• A transmission shift has occurred.
• The PCM detects excessive torque load.
• The PCM detects insufficient idle quality.
• The PCM detects a hard launch condition.
• Outside air temperature is detected to be below 38° F by the OAT sensor if equipped.
• The blower switch is turned OFF.
When the A/C compressor clutch is disengaged for any of these reasons, the A/C indicator LED will flash indicating A/C is not functioning. When the compressor clutch disengages, the compressor clutch diode protects the electrical system from a voltage spike.
Old May 20, 2009 | 06:59 AM
sonin66's Avatar
bowtie, where do you get your info?! i know in your name it says tech, but how do you go about getting that stuff
Old May 20, 2009 | 09:39 AM
RickAKATed10's Avatar
Photobucket
Good info. I'll have to keep that in mind if it ever happens.
Old May 20, 2009 | 10:12 AM
God_Bot's Avatar
^ Only times mine has ever flashed.
bkb1255
Apr 10, 2017 09:01 AM
RonKennesaw
Jan 5, 2015 04:49 PM
ErMiller79
Oct 19, 2012 05:17 PM
Cschlue
May 10, 2010 09:06 AM
warpath
May 23, 2006 10:54 AM
