2000 monte carlo a/c problem
Old Aug 7, 2011 | 11:57 AM
greghowell1124's Avatar
Default 2000 monte carlo a/c problem
i thought i would share a problem with the fix. i have dual climate control & have cold air on passenger & warm air on drivers side.if i raise temp on drivers side it gets hot. this told me the temp control was working.i checked for vacuum leak in dash -ok. i recovered the freon & pulled vacuum on a/c system. charged it with the correct amount of r134a freon (1.88 lbs.) i now have 38 degree air out both sides. i hope this may help someone else.
Old Aug 7, 2011 | 12:13 PM
BlackRainSS's Avatar
mine has yet to do it on either of my montes, both have the dual climate control, but I've heard this is a common problem with them and its great to know the fix in advance. Thanks for the info
Old Aug 7, 2011 | 10:27 PM
KJRich's Avatar
Mine does this too when the freon gets low. I have a small leak somewhere.
albatross
May 31, 2012 07:46 AM
inyanalili
Apr 2, 2012 08:31 AM
cynthiaf
Aug 25, 2011 07:40 AM
shawnmccune
Dec 22, 2010 12:34 AM
blk89convt
Jan 26, 2010 07:06 PM
