06 ss ac problems
Old Jun 2, 2011 | 08:30 PM
chaleyss's Avatar
Default 06 ss ac problems
its so weird, the compressor comes on , then off. but it works fine when the car is moving, but when i stop a a light or have it in park, it blows hot *** air. does anyone kno where to begin to look?
Old Jun 10, 2011 | 04:18 PM
Oddball's Avatar
you may have to service your a/c- add refrigerant. But before you do check to make sure your cooling fans come on when they are supposed to...Im not sure at what temps what speed is supposed to come on, but i know for sure that the low speed fan should come on whenever the a/c is engaged. If not, or if the high side pressure rises beyond a certain level, the compressor is disengaged. This can be due to high temps on the condenser due to insufficient cooling.
vampy1274
Aug 2, 2005 09:55 PM
besbekost
Jul 13, 2005 06:16 PM
montejass
May 5, 2005 07:37 PM
85_Monte_SC
Mar 22, 2005 01:05 AM
MonteCarlo04SS
Feb 25, 2005 11:28 AM
