6th Gen ('00-'05): Help Me Identify This Gas Leak (Pictures Inside)
Old Aug 26, 2014 | 03:14 PM
Yellowiscool's Avatar
Default Help Me Identify This Gas Leak (Pictures Inside)
A faint gasoline smell has quickly deteriorated to a genuine gas leak, although I do not know the name of the part(s) effected to research a fix-- so, can anyone assist?
The spray is light (I'm in no danger of emptying my gas tank from it, but I'm sure its a fire hazard), and seems to be emerging from between the "bracket" and the "canister"... whatever that canister is. In the first image, just to the left of the drop forming on the canister itself would be the origin.
All of this is located on the driver's side, roughly halfway back, a foot or two inward. My Monte Carlo is a 2002/2003 (I always forget) FWD.
Can anyone name what those components are called? Or give any other help?
Old Aug 26, 2014 | 03:16 PM
I believe that canister is your fuel filter, unless the lines rusted out, hopefully a new filter sill solve the issue.
Old Aug 26, 2014 | 03:37 PM
Fuel filter
Old Aug 26, 2014 | 08:59 PM
I'll have to inspect the lines when I get the time to jack it up, but replacing the fuel filter would be very easy. I hope that's the case!
Old Aug 27, 2014 | 07:53 AM
Earlier this year, I burst my fuel filter too haha
Hopefully it's a quick fix for ya
Old Aug 27, 2014 | 08:19 AM
03SSLE's Avatar
Your fuel filter has been on the car for so long it has literally rusted through. DO NOT drive the car until a new filter is installed. Otherwise you are driving a time bomb just waiting to go off.
Old Aug 27, 2014 | 09:40 AM
vikesfan's Avatar
i would replace the any rusted section of that line as well.
i have had great success just cutting off the rusted line and flaring the end, then using fuel injection fuel line and a brass fitting into the fuel filter to repair that section.
be sure to double clamp the hose if you do this.
MonteSquarlo
Dec 16, 2012 06:18 PM
SS02
Aug 8, 2012 12:03 PM
7498MonteCarlo
Sep 13, 2010 10:09 AM
Legacy3135
Jun 16, 2010 06:47 PM
Paranoid Vengeance
Apr 25, 2008 07:44 AM
