Help me identify this wire please!! 2002SS
Old Aug 7, 2012 | 08:51 PM
SS02's Avatar
Angry Help me identify this wire please!! 2002SS
Okay while trying to find another problem I found a stray wire under the engine cover...two pink wires.
also it looks like something was mounted on the tab that the rear part of the engine cover slides into...whazit?
THANKS
Old Aug 7, 2012 | 10:14 PM
SS02's Avatar
i have seen a bunch of engine bay pics but cant see what is mounted on the tab
Old Aug 8, 2012 | 01:07 AM
Budsjlm's Avatar
I do belive the is the infomous what does this plug into mysterious no use plug everyone asks about after doing a top swap or LIM gaskets,
Hobbled down to my car ( foot is swelled up twice the size it should be but I wanted a fig anyways) and confirmed that does not plug into anything,
I think it has been specualted that it's posibly a plug used on supercharged models or even somthing that shares the same wire harness
Old Aug 8, 2012 | 04:39 AM
blueSS's Avatar
Yea my non supercharger 3.8 also has that loose wire... no need to worry
Old Aug 8, 2012 | 06:00 AM
That bracket you point to is no concern. I believe what mounts to that is the California required Emissions Pump.
As for the wire, I'm not sure. I don't recall ever seeing a wire like that. GM is known for using a "1 size fits all" wiring harness sometimes (so some connections are not used all the time).
Old Aug 8, 2012 | 07:58 AM
Definitely the infamous wire to no-where. It attached to the california emissions pump
Old Aug 8, 2012 | 09:29 AM
SS02's Avatar
Thanks everyone! Whew!
Old Aug 8, 2012 | 09:32 AM
01 Monte SS's Avatar
I have the same thing so your not alone
I removed all of those brackets though. Free weight reduction But if you do be sure to keep 'em. They come in handy if you ever want to pull the engine out.
Old Aug 8, 2012 | 12:03 PM
Does this help at all?
Yellowiscool
Aug 27, 2014 09:40 AM
Blue04SS
Apr 11, 2014 09:16 PM
Legacy3135
Jun 16, 2010 06:47 PM
Paranoid Vengeance
Apr 25, 2008 07:44 AM
mykah89
14
Dec 16, 2007 12:11 AM
