Gas fill problem
Old 11-16-2009 | 03:11 PM
Steve A 454's Avatar
Question Gas fill problem
I have a 2001 Monte Carlo SS with the 3.8. Whenever I try to fill up the gas tank, the gas pump keeps shutting off before the tank is full. It doesn't matter how you hold the nozzle, upside down, sideways, all the way in, or just inside the filler neck. It eventually will fill if you hold the nozzle lever at the slowest possible fill rate. Anyone have any ideas ?
Old 11-16-2009 | 03:50 PM
Could have an issue with the venting of your tank. Maybe something clogging
Old 11-16-2009 | 04:33 PM
Does it happen all the time? It might just be the pump.
Old 11-16-2009 | 04:50 PM
I happens all of the time, no matter which gas station that I go to.
Old 11-16-2009 | 07:26 PM
rogg5204's Avatar
Definitely sounds like an issue with the vent on the tank. It is just like pouring gasoline out of a gas can, if you don't open the vent, the gas doesn't come out very well. Same thing with filling up the gas tank, you are pumping in all that fuel very quickly and without a way to push out the air, it can't properly fill the tank.
Old 11-16-2009 | 09:48 PM
Enzo354's Avatar
STILL SLOW
Yea mine does the same exact thing... my pump at home has no auto shut off and works fine but it goes slower. If your in no hurry fill it at about half trigger and see how that works. So yea check out the vent, Ill try it too.
Old 11-16-2009 | 10:11 PM
mrl390's Avatar
Mine does it sometimes too. What I do is pull the nozzle out a little so the fume cap doest cover the fill hole. That lets enough fumes out to relieve the pressure and allow the tank to fill properly. Dont worry, it will still automatically shut the flow off when the tank is full.
bluemonte0709
01-08-2010 11:00 PM
Scooby doo
12-29-2009 06:02 PM
Evil03SSCarloGuy
04-25-2008 01:05 PM
White05LT
08-29-2006 11:33 PM
Birge
12-30-2004 04:09 PM
