engine code, can anyone explain it in english?
Old Nov 17, 2009 | 04:01 PM
skylark65's Avatar
Default engine code, can anyone explain it in english?
yup, the monte threw another "service engine soon" light, figured i would try my new scanner on it. the only code was:
P1652
manufacturer control
auxilery imputs
auxilery outputs
the car is running like crap now, does anyone know what the hell that code means? it sounds like my car wants me to ditch the stock radio & get a head unit, lol, but i know thats wrong
for anyone who does not know, the car is a '97 LS, stock 3.1 and 153,000 miles.
can anyone assist?
thanks much!
Old Nov 17, 2009 | 04:14 PM
nitehawkjcb's Avatar
I'm not 100% sure, but I think that's the code for the Vehicle Speed Sensor.
Old Nov 17, 2009 | 04:30 PM
Jomao_o's Avatar
ah, its one of those days, my "check engine" light came on today for me, and i feel like ****!
Old Nov 17, 2009 | 04:48 PM
skylark65's Avatar
yep, one of those weeks is more like it, lol.
nighthawk, i gotta ask, what is the vehicle speed sensor? god, there are so many sensors, lol, i gotta grab my haynes manuell & look it up, but mabe you might know a quick summery ? thanks for the starting point
Old Nov 17, 2009 | 06:23 PM
d'oh left my book at work! SORRY
Old Nov 17, 2009 | 06:54 PM
RocknSS04's Avatar
P1652 = Electric Cooling Fan 2 Relay Control Circuit
Your relay for fan 2 is giving you problems. Can't tell you which is #2, but I'd guess the passenger side
Google your trouble codes as "monte carlo p1652 obdII", and you get things like these:
http://www.aa1car.com/trouble-codes/...1500-p1699.htm
and a GREAT one:
http://www.mobile-abgastester.de/Dat...ercodes/GM.pdf
There are others, and it isn't always the same. If it was a Cadillac or Corvette it could be Powertrain Induced Chassis Pitch Output Circuit.
Always check a couple of sites. The 2nd site actually reads:
P1652 Fan 2 Relay Control Circuit (Except Cadillac & Corvette)/VSS Output Circuit (1996 Corvette)/Powertrain Induced Chassis Pitch Output Circuit (1997- 98 Corvette)/Lift/Drive Output
Circuit (Cadillac)
Haynes manual says it's the fan relay also.
So now google "monte carlo fan 2 relay circuit", and you get:
The fans are controlled by 2 relays that are located in the fuse box mounted on the right fenderwell.
The fans get their power from the relays through the light blue wire from relay 1 to fan 1 and the white wire from relay 2 to fan 2. The black wires on both fans are ground
If the relays are dead, they get their power through the red wires from the 2 60amp maxi fuses in the same box.
Note: The Powertrain Control Module (PCM) activates the relays by "reading" a signal from the engine temperature sensor. A malfunction in this system will show up as a fault code P0117 or P0118 and the fans will not operate properly
So there's your answer, hopefully. A bad relay (or bad connection) from the relay labeled #2, and the fan with the white wire.
Old Nov 17, 2009 | 08:45 PM
skylark65's Avatar
wayne, that is some awsome info, thanks a ton! im gonna have to look the fuse box over tomorrow after school, i gots a feeling it could be the toggle swich one of my car's PO's rigged into the fan circut, scince i had it on (due to a little traffic) when the light came on. THANKS AGAIN!
Jparks
Apr 16, 2012 01:51 PM
jeffsmonte
May 14, 2010 07:18 PM
monte carlo 3831
May 15, 2009 12:12 PM
RickCoMatic
Jul 25, 2008 05:54 PM
BLACK ATTACK
Sep 24, 2007 09:18 PM
