Gas fill problem
Old Nov 16, 2009 | 02:11 PM
Steve A 454's Avatar
Question Gas fill problem
I have a 2001 Monte Carlo SS with the 3.8. Whenever I try to fill up the gas tank, the gas pump keeps shutting off before the tank is full. It doesn't matter how you hold the nozzle, upside down, sideways, all the way in, or just inside the filler neck. It eventually will fill if you hold the nozzle lever at the slowest possible fill rate. Anyone have any ideas ?
Old Nov 16, 2009 | 02:50 PM
Could have an issue with the venting of your tank. Maybe something clogging
Old Nov 16, 2009 | 03:33 PM
Does it happen all the time? It might just be the pump.
Old Nov 16, 2009 | 03:50 PM
I happens all of the time, no matter which gas station that I go to.
Old Nov 16, 2009 | 06:26 PM
rogg5204's Avatar
Definitely sounds like an issue with the vent on the tank. It is just like pouring gasoline out of a gas can, if you don't open the vent, the gas doesn't come out very well. Same thing with filling up the gas tank, you are pumping in all that fuel very quickly and without a way to push out the air, it can't properly fill the tank.
Old Nov 16, 2009 | 08:48 PM
Enzo354's Avatar
STILL SLOW
Yea mine does the same exact thing... my pump at home has no auto shut off and works fine but it goes slower. If your in no hurry fill it at about half trigger and see how that works. So yea check out the vent, Ill try it too.
Old Nov 16, 2009 | 09:11 PM
mrl390's Avatar
Mine does it sometimes too. What I do is pull the nozzle out a little so the fume cap doest cover the fill hole. That lets enough fumes out to relieve the pressure and allow the tank to fill properly. Dont worry, it will still automatically shut the flow off when the tank is full.
bluemonte0709
Jan 8, 2010 10:00 PM
Scooby doo
Dec 29, 2009 05:02 PM
Evil03SSCarloGuy
Apr 25, 2008 12:05 PM
White05LT
Aug 29, 2006 10:33 PM
Birge
Dec 30, 2004 03:09 PM
