Power Steering on 3.8 and how to fill??
Old Aug 25, 2006 | 09:34 PM
White05LT's Avatar
Default Power Steering on 3.8 and how to fill??
I have read that the power steering unit is down by the firewall on the passengerside. How do you check the fluid level and how do you fill it??
I'm wondering because I'm getting a very odd click noise from the wheels whenever the wheels are turned to the left or to the right, I notice it when the car is stopped, or when I'm turning at very low speeds, for instances from a complete stop. The window has to be open for me to hear it, if the window is closed you can't notice it. The dealer has already replaced an axle and the strut mount on the driver side. I'm thinking maybe power steering???
Old Aug 25, 2006 | 10:16 PM
montejass's Avatar
Default RE: Power Steering on 3.8 and how to fill??
It's a royal PITA to get to.
I've had the cap off, "ONCE"..... It's all the way towards the bottom of the engine as well. Have you located it yet?
You will need a super long funnel to add to it..
Old Aug 25, 2006 | 10:52 PM
DESS03's Avatar
best way is with one of those funnels with the fexable spout and a lot of patience
Old Aug 25, 2006 | 11:07 PM
02montels's Avatar
That click you hear is normal. Its due to the craddle being all aluminum on our cars. I read there was a TSB for that, at the dealer they remove all the bolts that are in the craddle and apply some type of lubricant to it to stop the noise. But it is totally normal and nothing to worry about.
Old Aug 25, 2006 | 11:20 PM
montejass's Avatar
Loctite is what they use if memory serves me correctly...
Old Aug 27, 2006 | 08:02 PM
White05LT's Avatar
I'd like to check it anyways, i have a flexing funnel. But I still can't find the reservoir. Any photos?
Old Aug 27, 2006 | 08:09 PM
DESS03's Avatar
its up under the alternator up againt the firewall
Old Aug 27, 2006 | 08:43 PM
montejass's Avatar
I've heard of some reaching it metter from under the car. I have not tried this yet but like Dess noted, it's way down there.
Old Aug 29, 2006 | 10:33 PM
White05LT's Avatar
Well I finally got to check the fluid while doing the U-Bend. I figured while I was under the car (which was on a lift) I would give you guys a snap shot to work with. Good luck to those trying to reach it....ITS NOT EASY!
reesgriff
Jun 10, 2022 08:05 AM
TomF106SS
Oct 6, 2014 10:13 AM
ashleymc
Aug 29, 2012 08:44 AM
DenaliZO6
Apr 13, 2010 08:35 AM
