Death wobble
Old Nov 20, 2018 | 11:30 PM
Cindy Clark's Avatar
Default Death wobble
My Montie is 2001. It has a terrible death wobble when accelerating. Its on passenger side. Cant feel it threw the steering wheel. Have changed axel, A arm, hub assembly, wheel bearing, all four motor mounts an rotated tires. HELP WHAT ELSE COULD IT BE???
Old Nov 21, 2018 | 06:26 AM
Smile
Tires? Has the vehicle been to the alignment shop.
Old Nov 21, 2018 | 07:04 PM
Death wobble is a Dodge Ram issue
In all seriousness, does it happen at all speeds or high speeds? Has anyone put the front end in the air and wiggled the tires and checked for loose/broken parts? Generically thinking, these ideas come to mind (and are usually easy to check):
- Broken sway bar end links
- Broken sway bar
- Worn out sway bar bushings
Going deeper:
- Worn brake rotors (I had some that caused a horrible shimmy while braking on a different car).
- Bent rim
- Tie rods
- May need to diagnose components on the other side.
ziggo_2
Feb 7, 2021 03:34 AM
mikeymoe
Sep 19, 2017 07:21 PM
MJClemm
Sep 16, 2013 11:57 AM
owens91
Jul 10, 2013 05:55 PM
laredoggg
Nov 16, 2006 04:47 AM
