Death wobble
My Montie is 2001. It has a terrible death wobble when accelerating. Its on passenger side. Cant feel it threw the steering wheel. Have changed axel, A arm, hub assembly, wheel bearing, all four motor mounts an rotated tires. HELP WHAT ELSE COULD IT BE???
Originally Posted by Cindy Clark
(Post 715097)
Death wobble is a Dodge Ram issue ;)
In all seriousness, does it happen at all speeds or high speeds? Has anyone put the front end in the air and wiggled the tires and checked for loose/broken parts? Generically thinking, these ideas come to mind (and are usually easy to check): - Broken sway bar end links - Broken sway bar - Worn out sway bar bushings Going deeper: - Worn brake rotors (I had some that caused a horrible shimmy while braking on a different car). - Bent rim - Tie rods - May need to diagnose components on the other side. |
