A/C Problems, perhaps stemming from an electrical short
Old Sep 13, 2006 | 07:20 PM
InTheIROC's Avatar
Default RE: A/C Problems, perhaps stemming from an electrical short
The LED on the dash does not mean that the compressor is running, it just means you have the A/C system turned on and the compressor will run when it needs to (or at least, it should). If the pressures in the A/C system are incorrect, it will not run or won't run for long. I'm not sure about GMs system, but it could very well be related to the engine temperature. If the computer doesn't know the temperature of the engine, it doesn't want to allow the A/C to kick on and give the engine an increased load.
Old Sep 16, 2006 | 03:16 AM
enibum's Avatar
Your probably right about the temp sensor. I'll take a look at it this weekend. Maybe just a loose connection at the sensor. Or even a bad sensor would be alright. While I'm at it, are the temp sensors on these cars located on the intake near the water pump end of the motor?
TimberJohn
Feb 24, 2016 12:33 AM
kev01SS
Mar 4, 2015 11:38 AM
CyB3R_D3MoN
Jan 6, 2013 08:52 AM
piyushbali
Aug 15, 2010 01:37 PM
