2001 Monte 3.4sfi electrical short?
Old Jan 5, 2013 | 09:34 PM
CyB3R_D3MoN's Avatar
Default 2001 Monte 3.4sfi electrical short?
Hello I have an 01 monte and it dies overnight all the time. I've done the parasitic test I believe its called(take positive off and put tester to cable and battery) and its showing .47, now this is sky high I know that. I narrowed it down to a circuit in the under the hood fuse compartment on top. Its a 60 amp and labeled LEFT I/P 242. The is 0 draw from the battery when I unplug that fuse. Does anybody have a wiring diagram for this circuit? If anyone does that would be great! Also, my windows stopped working completly at once just the other day. No fuses are blown, possibly a relay? If so which relay? Thanks y'all!!!!
Old Jan 6, 2013 | 08:52 AM
03SSLE's Avatar
From what I can tell looking at a (basic) schematic, the 'Left I/P' protects a circuit which provides power for the lighting circuits through the Left I/P accessory wiring junction block. Since there are several different components that receive power through the junction block you will need to continue checking circuits.
kev01SS
Mar 4, 2015 11:38 AM
mskrib002
Sep 24, 2012 02:44 PM
hatecc
Sep 16, 2006 03:16 AM
