Bad wires?
#41
Well as soon as he heard it run he said it was SHOT LOL because of the very loud knocking sound and the engine shaking like crazy he said it was from coolant leaking into the oil and messing the engine up. He also said that cylinder 6 and I think 2 wasn't working so he is going to look for a cheap motor for me but its expensive to get it put in. So if anyone knows of a place that can do the work for a decent price let me know cuz I don't want to get another car I love the Monte
#42
You have a Series II 3800 if I recall? Upgrade to a Series III. From everything I understand, it's a simple process to put a SIII into an SII car (and SIII is identical, with minor exceptions, such as an aluminum UIM, which you can either adapt a L67 throttle body too or swap to a SII LIM, and I've heard the internals are made of strong materials for better durability).
That being said, make me an offer on this....
![Wave & Point](https://montecarloforum.com/forum/images/smilies/wave&point.gif)
https://montecarloforum.com/forum/pr...mission-33965/
And if you choose not to make me an offer, I would still consider sourcing a Series III 3800.... Started in 2004, has almost (if not all) the same performance mod options as the Series II 3800.
#43
No I thought I had said that it was a 3.4 not 3.8 sorry for that LOL but if your engine would still fit ill definitely make u a offer and I still have to take in effect the cost of having someone put it in for me cuz I don't have the equipment to do a job like that or the knowledge
#47
A 3800 will fit in a 3400 W-Body car. BUT, it will require the correct wiring harness, PCM and possibly some other items. It's a nice upgrade, but if money is tight, you are best off hunting a good 3400 (as it's a direct swap).
But if you want to look at a 3800 swap, there are a lot of posts with more knowledge then I have on the 3.4 to 3.8 swap.
Also, since you have a 3400, I believe the model transmission is the same BUT the gearing in it is different then that of a 3800 (don't quote me). So if you are looking to make the switch, I have engine and trans together for sale.
#48
About a week before all this started with my car I had seen something called a vacuum connect valve laying on my transmission does anyone know Wat that is suppose to go cuz I have no idea and the only reason I knew the name is because I had seen a pack of them hanging up in autozone
Here's a pic of it
Here's a pic of it
![](https://montecarloforum.com/forum/members/montecarlos26-13397-albums-garage-daddys-girl-1904-picture-imag0050-13916.jpg)
TMoney
04-09-2014 09:32 AM
Cowboy6622
02-06-2012 10:56 AM
BigPana
27
06-24-2011 11:37 AM
