5th Gen ('95-'99): Anybody know where to find dome light circuit?
I've seen those, my step dad has a set for his Fiero. Those are sweet. I would love to see a company could do the Monte knight's crest!
I believe you can find it in the kick panel. I forget on the exact color of the wire. I've tapped into it more than once before. I could look at my car and see if I can find where I tapped into it.
You could, but I believe these projectors are installed in the bottom of the door. That would be a long ways to run the wire if you tapped into the dome light. Plus, you'd have to take apart all of the trim around the headliner to run the wire. I would think tapping into the circuit at the kick panel which is closest to door where the wire would be run would be the simplest.
If you could do that, it would be great! Thanks!
I'll check this weekend. I'm planning on doing some work to it and cleaning it up so I can let you know
